stereopi hats wtf ?
Other hardware discussion
zoldaten
stereopi hats wtf ?
Post by zoldaten »
I was making a case to stereopi and got ready to put on new hat for it -
zero2go omni -http://www.uugear.com/product/zero2go-o ... pberry-pi/
It`s very convinient as one can power pi from different sources, correct shutdown and etc.
But i found out that GPIO header of stereopi is reverced !
While the standard GPIO header looks like this -
So i couldnt place a hat standard way -
I put it reverced ! Facepalm. :shock:
It working but now i can forget about cosy case ((
Pi-hat i connected is sticking out...
Re: stereopi hats wtf ?
If the GPIO connector was the way around, the pi-hat would cover the camera connectors.
Since the cameras are primary functions with this board, it is probably better this way.
zoldaten
Post by zoldaten »
May be you`re right.
But with this - https://aliexpress.ru/item/1005001451035151.html
it`s easy to solve coverage problem.
@zoldaten JFYI, we fixed the GPIO position in the new board. As for the tall header mentioned - yep, this might be an option.
zoldaten
Post by zoldaten »
Realizator wrote: Mon Mar 22, 2021 4:18 pm @zoldaten JFYI, we fixed the GPIO position in the new board. As for the tall header mentioned - yep, this might be an option.
sounds good !
