Are there cables available for wider basis?
Posted: Sat Mar 27, 2021 6:30 pm
the StereoPI V2 has connectors for two cams. These connectors are aligned horizontally in a certain distance.
I want to built a camera with flexible basis so I need to move the cams horizontally to the desired distance.
The problem is one can bend the flat cable only in one direction, as it is flat.
With the current horizontal alignment of the two connectors on StereoPI I can move both cams up and down - this is the way the flat cable can bend easily.
But I need to move the cams horizontally to get a bigger distance between them - but the flat cable I cannot bend horizontally
I hope it is clear what I mean.
Can I fold the flat cable like this?:
Are there (round) cables available which I can bend in horizontal direction?
Or is there another way to solve this problem?
