Load camera (V1) parameters from a JSON file
shaid
Post by shaid »
Is there a way to configure via picamera each camera (left / right) with different parameters and save the data in a JSON file to be used at startup?
Good Day
Shai Dorot
Re: Load camera (V1) parameters from a JSON file
Hello Shai,
At the startup, cameras are not turned on at all. You can set the parameters you need in the software you are using.
Also, if you are using the stereoscopic mode, you can't set different parameters for cameras - they are automatically synchronized. But for the independent use of each camera you can set any parameters you need.
