My v2 display came with a connector with 7 wires, not 8. One isn't missing, I guess it's just the wrong one. There are 8 pins on the board.
In the setup instructions, https://wiki.stereopi.com/index.php?tit ... stallation, you can see purple, white, green, orange, yellow, blue, brown, grey. Mine is missing white.
I'll probably just buy another, since it's fairly cheap. https://www.waveshare.com/product/displ ... module.htm
LCD cable has 7 wires, not 8.
- 7 wires not 8, no white.
- whyzorz.jpg (82.25 KiB) Viewed 56669 times
Re: LCD cable has 7 wires, not 8.
Hello burpshirt,
Did you get this display with the kit?
Could you please share the photos of the PCB with the connector and pins names?
You see, actually not all the wires are used while the LCD is working. For example, screen suspend mode wire.
Yeah, it came in the kit. Here's a photo.
- display.jpg (388.81 KiB) Viewed 56631 times
The replacement screen I got has the right cable.
