StereoPi recording issue
cecilolkia
Post by cecilolkia »
Hello Guys,
While experimenting with my setup, I noticed, that the enabling of audio only records mono sound. I attached a Tascam stereo recorder, which is used as a USB interface. I want my StereoPi to be stereo, in picture and sound.
What do I have to do to achieve this?
Thanks in advance.
PS: Microphone Test allows you to determine if the microphone on your device actually works.
This online mic test is useful in order to find out if microphone issues come from the device itself (os or hardware issues) or from an application (broken application or bad application settings). If your microphone fails this online mic test, the issue most likely comes from the device itself. On the other hand, if your microphone passes this test but still doesn’t work in a specific application, the issue comes from the application.
Re: StereoPi recording issue
Hey Cecilolkia,
You do can record the stereoscopic audio. This question (and the solution) was discussed in this topic.
