stereoPi upgraded case
Cases, camera mount mechanics, 3D printing, laser cut etc.
NiamoR42
Post by NiamoR42 »
perhaps it could help you : I did some modifications on the current stereoPi case.
you can find the cad and freecad project here : https://www.thingiverse.com/thing:3633970
I remove these volumes on the current design :
result (I have to improve my 3D printer...) :
You are able to use screw & bolt to fix the card =)
NiamoR42
Re: stereoPi upgraded case
NiamoR42, wow, that's great, thank you for sharing!
By the way, are you planning to add vent holes at the bottom, or you have no temperature issues? Are you using CM3 or CM3+?
NiamoR42
Post by NiamoR42 »
Realizator wrote: Thu May 23, 2019 9:49 am NiamoR42, wow, that's great, thank you for sharing!
why not, I'll see it by using the stereoPI.
it's true that the glue gun was good but, with the temperature, the cover takeoff. I may need to use others screw.
