How to work with Stereo Pi
Share your projects and ideas with the community!
Re: How to work with Stereo Pi
Okay, let's try from the very beginning.
Do you have any HDMI monitor, USB keyboard and USB mouse? Or you're using a notebook (laptop)?
Bhavya
Post by Bhavya »
Helloo...
I'm using the 64bit desktop,I have connected hdmi cable and mouse and keyboard,I have changed user name to pi.and I'm going to do my c++ code in netbeans IDE 8.2,and puTTY compiler im using as console.I'm going to execute the script1.cpp but build failed. Im attaching the files below. help me to proceed next.
Thank you..
Can you exclude your desktop from this experiment?
Try to connect mouse, keyboard and HDMI monitor directly to your StereoPi, and compile/run examples like shown on our video?
Bhavya
Post by Bhavya »
Helloo..
Is there any possibility to do without HDMI cable?
I don't want to do with HDMI cable so..
Thanks and regards
Bhavana
Bhavana, without HDMI cable (by putty in your case) you can:
- access to the code onboard
- run compilation command (onboard, but not from your MS Visual Studio)
- run the binary compiled
But you will not be able to see the result, as all data (like images, depth map etc.) are shown on HDMI output only. Over Putty you can see just a console messages.
Bhavya
Post by Bhavya »
- run compilation command (onboard, but not from your MS Visual Studio)~>Here im not using Visual studio,I'm using Netbeans IDE8.2
Bhavya wrote: Wed Mar 04, 2020 12:52 pm Hi
Bhavana, I recommend you to start with just a repeating all the steps from the very first tutorial and the very first video. Without external Windows machine, but just with the connected keyboard, mouse and HDMI monitor to your StereoPi and OpenCV image.
When you can do this 1st step, we can move further. Step by step.
I agree with Realizator: if you choose the opencv way, which is a bit advanced, following the step by step video tutorial is a good idea.
You do not need your PC for the opencv way. All is done on the stereopi, including the compilation, display and even desktop-like interaction with software. Just plug USB keyboard, mouse and HDMI screen and follow the video steps to familiarize yourself with the way to do things in this context.
When you will be confident with the tutorial, you might do headless processing depending on your needs, although displaying the image live might still be useful during writing to check that the processing does what is expected.
Bhavya
Post by Bhavya »
Helloo
Thanks for the help..I will proceed as you informed.
Thanks once again Realizator
Bhavya
Post by Bhavya »
helloo..
Can you please tell me how to install StereoPi library for c++?
Thanks and regard
Bhavana
Hi Bhavana,
What do you mean under C++ library for the StereoPi? We have no special libraries. Just install OpenCV and use it. If you are working with our latest OpenCV image, all software you need already installed.
Bhavya
Post by Bhavya »
Helloo..
~I mean without python i need to use stereo libraries, so for that i have mentioned c++.
how to check that in installed opencv whether the stereo libraries are present or not?
Thanks and Regrads
Bhavana
In our image we compiled OpenCV from sources, with all stereoscopic libraries.
So you can take OpenCV sources and compile them.
