Camera 1 not detected
chansek
Post by chansek »
I recently purchased the StereoPi for my projects. Unfortunately, I have not been able to get this working. I'm unable to get the 2nd camera to be detected.
I have done the following:
1. Installed the image with raspbian stretch & opencv from stereopi. vcgencmd get_camera says 2 cameras are supported but only one detected and its always camera 1. raspistill -cs 0 works, but raspistill -cs 1 outputs the following.
2. I tried with a fresh raspbian image via noobs and I get the same error as above.
3. Swapped the cameras and still the same. Bought new cameras and still the same. All cameras used are Raspberry Camera Module v2
4. I tried to blow into the connector to remove dust or other impurities and it does not change the outcome.
AFAIK I have followed pretty much everything said in the forums to ensure that my cameras are not defective or that my installation was not proper. I have been using the dt-blob.bin from stereopi and copied them into the boot folder.
Is there anything I might have missed? My conclusion at the moment is that the board is defective. Can you help, please?
Re: Camera 1 not detected
Hi Chansec,
As I understand you've tried all possible troubleshooting approaches, so no need to add some more tests. I've wrote you direct email (to the email address you used for registering on this forum) to discuss replacement details. Please answer.
