command line
Other software discussion
bchamp
command line
Post by bchamp » Thu Jan 16, 2020 11:06 pm
How can I set up the stereopi to access the command line? I would like to run scripts to take pictures at specific time intervals
Re: command line
Post by stereomaton » Fri Jan 17, 2020 8:41 am
If you use SLP variant of the operating system (which is the default delivered with the kit), remote console access is enabled by default through SSH protocole. See https://wiki.stereopi.com/index.php?tit ... 99_section for credentials.
Re: command line
Post by Realizator » Fri Jan 17, 2020 2:44 pm
Stereomaton thank you! :-)
Bchamp, do not forget to unlock a filesystem before changes! Also we have MC installed in SLP, so you can use it if you like.
