Hello everyone,
I have a problem.
I get this error when running 1_test.py in tutorial;
ValueError : buffer object must be one-dimensional and have unsigned byte format ("B").
"raspistill -cs 0" - OK
"raspistill -cs 1" - OK
Can you help me?
Thanks.
Re: ValueError : buffer object must be one-dimensional and have unsigned byte format ("B").
Hi Megil,
As a rule, such an errors appears if you're installing our tutorial scripts on a Raspbian with a newer Python or OpenCV version.
Solutions:
1. [recommended] Use the latest code and Raspbian image. This is Buster-based image and a code from this repo: https://github.com/realizator/stereopi-fisheye-robot
You can find downloads link in this repository description file.
(JFYI: This is updated version of older "https://github.com/realizator/stereopi-tutorial" code)
2. You can use previous code https://github.com/realizator/stereopi-tutorial and appropriate Stretch image
3. If you're advanced user, you can prepare appropriate Raspbian image by installing OpenCV as mentioned in this guide.
UPD> According to your another post on our forum, I can suggest you're using Ubuntu Mate. In this case it is better to follow step 3.
Solutions:
I'm using Ubuntu-Mate.
The codes I use are the latest in your github repository.
Okay.megil wrote: Tue Dec 24, 2019 2:00 pm I'm using Ubuntu-Mate.
1. Which repository you're using now?
2. For our python codes you need to use python3. In our image we've tuned system, so running "python 1_test.py" actually runs python3, that is "python3 1_test.py". Have you tried to run "python3" instead of "python"?
I tried it with python3 but it didn't work.
I think I have a bug related to numpy, I used PiRGBArray instead of numpy. I solved the problem.
Thanks.
Thanks.
It's great that you've solved your issue!
