Port to Oculus Quest
Knochi
Post by Knochi »
I already mentioned here, that i tried to run the Go App on Quest without success.
Seems that there are only small changes needed, because generally Go Apps should run on Quest.
I did a new threat to get a bit more focus on that, cause a many people own a quest and i think it's THE headset for that kind of stuff.
Cu Knochi
Re: Port to Oculus Quest
Hi Cu Knochi,
You see, it is the most painful task we have now. All the teams we've contacted to port our application to Oculus was unable to solve this task. :-( At this moment we're still in a process with 2 teams. In a case of success we will release native Oculus Go/Quest application.
Knochi wrote:
Fri Sep 27, 2019 10:16 am
I did a new threat to get a bit more focus on that, cause a many people own a quest and i thing it's THE headset for that kind of stuff.
Cu Knochi
By the way, for uploading our Android application to Oculus Go we've changed manifest file. If you can help us to understand what should we fix for Quest sideloading - we'll try this!
Knochi
Post by Knochi »
Fri Sep 27, 2019 10:25 am
I already tried the manifest changes proposed by oculus and others, without success.Maybe you want to give it another try.
Here is the official doc from Oculus:
https://developer.oculus.com/documentat ... -manifest/
and here a reddit Threat:
https://www.reddit.com/r/OculusQuest/co ... um=ios_app
Knochi thank you!
We'll try to test this!
Gol
Post by Gol »
Here is updated .apk with new manifest
StereoPi-OculusGo.zip
(1.82 MiB) Downloaded 115 times
Also i fixed green screen at secondary runs.
Works fine on Oculus Go, please, test it on Quest.
kru64
Post by kru64 »
No run on Quest. I see live stream only in Skybox with a great latency.
kru64 wrote:
Mon Oct 07, 2019 5:09 pm
It's bad :-/
We need a Quest for tests. Will try to find one.
Gol
Post by Gol »
Not installs or not found in Library -> Unknown Sources -> com.virt2real.stereopi ? Or not starts? Any error messages?
kru64
Post by kru64 »
Apk installed OK. See it in com.virt2real.stereopi. Run, but none start.
Mr-Qu33f
Post by Mr-Qu33f »
I just got a quest last week, tried the new APK and had no luck with mine either.
Is there anything I can do to help?
Deluxe Stereopi + CM3 lite
Mr-Qu33f
Post by Mr-Qu33f »
Has anyone had any success yet? I'm curious as to whether it would work by setting the quest to 3dof mode? I'm unable to test this myself at the moment as I'm currently away but might be worth a try
Mr-Qu33f wrote:
Fri Nov 08, 2019 3:15 pm
We got Oculus Quest and was trying to solve this task for a week. A lot of new experience, but no success.
Debug shows that our application (workable at Go) is:
- starting (black screen with a dots)
- discover StereoPi's IP address
- requests video stream
- decodes it and send to visualisation
After that application dies in approximately 20 seconds. Looks like visualization part is broken, and decoded video buffer is overfilled. We've tried a lot of fixes and approaches, but this thing does not work. I think we'll stop our investigations at this moments. All external programmers (with Oculus experience) was unable to solve this task. We were unable too. Unfortunately, this task needs too much time.
We can spend a day or two more, if you have some suggestions for us to check.
Mr-Qu33f
Post by Mr-Qu33f »
Do you have the adb logcat log to see what point it crashes?
Snakinola
Post by Snakinola »
Was any one ever able to figire out how to get the stereopi to livestream to the oculus quest?
Snakinola wrote:
Sat Apr 25, 2020 12:36 am
Nope... Not yet.
