How to get SPI0 working
Other hardware discussion
dusinnhht
Post by dusinnhht »
Hi!
I'd like to use SPI0 on the StereoPi. I use the standard and latest Raspbian. I enabled SPI with raspi-config and rebooted several times, but ls /dev/spi* doesn't give any result.
Then I enabled SPI1 (added dtoverlay=spi1-3cs to /boot/config.txt), and it seems to be working. (I now have /dev/spidev1.0, /dev/spidev1.1 and /dev/spidev1.2) Pinout is here: https://pinout.xyz/
Did anyone have any luck enabling SPI0?
dusinnhht
Re: How to get SPI0 working
Post by dusinnhht »
I just noticed, that SPI1 is in fact SPI0, at least it drives the pins for SPI0. It's weird, because when I connected SPI1's Mosi with Miso it passed the test. But what I connected to SPI1 bus didn't work, so I checked the other pins with oscilloscope and noticed that SPI0 pins are driven (also? I didn't check SPI1, just wanted to get over with the project, but I still dont have /dev/spidev0.*)
Hi dusinnhht,
Which pins are you using for SPI0?
If we'll look inside Compute Module datasheet, page 18 and 19, we can see that SPI0 can bu used either at GPIO 7-10 (ALT0), or at GPIO 35-39 (ALT0).
And if we'll look inside our device tree configuration (dt-blob.dts), we can see that some of these pins are used for the second camera control.
To check this hypothesis, please try to rename dt-blob.bin in your /BOOT partition and run your tests. With no dt-blob.bin our StereoPi will act exaxtly as a classic Raspberry Pi.
If this will work for you, we'll try to slightly modify dt-blob for you, to release the pins you need.
