ROS depth map error
minar
ROS depth map error
Post by minar »
Hi
I am trying to get the example code on https://github.com/realizator/StereoPi- ... h-map-test running but with the current Ubiquity image (12-02-2019) I am getting an error, "Camera is not enabled." The camera interface is enabled via raspi-config.
Any ideas for help?
Re: ROS depth map error
minar wrote: Thu Jun 06, 2019 6:23 am Hi
Any ideas for help?
Hello Minar,
Please try to run "raspistill -cs 0", and after that "raspistill -cs 1" to check, if raspistill and camera subsystem works?
minar
Post by minar »
Hi Eugene
"raspistill -cs 0/1" failed as well and vcgencmd get_camera returned supported=0 detected=0
I found a solution though:
I copied the /boot/dt-blob.bin file from the stereopi image into the Ubiquity boot folder and that got it to work.
Also missing were ros-kinetic-stereo-image-proc and ros-kinetic-image-view.
Now it works - I branched on github. Thanks for the example!
Great! I'm glad it works for you!
My next plans is to calibrate wide angle cameras for upcoming robot experiment. :)
