Is it possible to change the path for the video recordings in S.L.P. image?
I have a 1TB mSata SSD module mounted and I’d like the recordings to be stored there directly.
Change the path for video recordings?
Re: Change the path for video recordings?
Yes, you can.
Our start script is here:
/opt/StereoPi/run.sh
In this script we mount partition for video as a /media.
So you can change mount rule according to your SSD name.
Please also check our FAT32 format logic in this script. You may comment format commands or change them according to your needs.
sudo mount /dev/mmcblk0p3 /media > /dev/null 2>&1Please also check our FAT32 format logic in this script. You may comment format commands or change them according to your needs.
Great! Thank you very much!
