Google Coral Installation with Compute Modules
Posted: Mon May 13, 2019 10:40 pm
If you're planning to install Google's Coral Accelerator with EdgeTPU support, you will need to edit the install.sh file that is ready after you download and untar the tarball. The install.sh script checks
and compares that string to the stored strings. The Compute Module is not listed among them. I have included here the entire section with the Compute Module's Model Line included:
Save that and run the script. Installation of EdgeTPU will be successfully completed.
Dave Xanatos
cat /sys/firmware/devicetree/base/modelCode: Select all
if [[ "${MODEL}" == "Raspberry Pi 3 Model B Rev"* ]]; then
info "Recognized as Raspberry Pi 3 B."
LIBEDGETPU_SUFFIX=arm32
HOST_GNU_TYPE=arm-linux-gnueabihf
elif [[ "${MODEL}" == "Raspberry Pi 3 Model B Plus Rev"* ]]; then
info "Recognized as Raspberry Pi 3 B+."
elif [[ "${MODEL}" == "Raspberry Pi Compute Module 3 Plus Rev"* ]]; then
info "Recognized as Raspberry Pi CM3+."
fi
Dave Xanatos
