Hello to everyone.
Initially, everything worked well. But after a two-month break in development, today I launched StereoPi and did not receive from HDMI image. Only the first camera's LED is on, both cameras are workable. An attempt to see the image through the application on the phone was a failure. I thought that the problem would be solved by loading a fresh SLP image (0.2.3), but the problem remained. I can connect via ssh, local IP, but there is no image. With the commands "raspistill -cs 0" and "raspistill -cs 1" nothing happens, the programs hang, I have to interrupt them. I suspect that this is a software problem, please tell me, in what configuration files I should see the initialization of the cameras?
Not working cameras
Re: Not working cameras
Hi!
First notice: our S.L.P. image uses the cameras all the time. So if you try to use raspistill you get an error like you have, as both S.L.P. and your raspistill instance will try to access cameras at the same time, and conflict appears. To avoid this, stop our scripts by running "stop.sh" here:
Do not try to use "killall" for raspivid, as our scripts will automatically restart it. Just run "stop.sh"
Second notice: built-in Raspbian stereoscopic mode support uses the only camera LED. That is while both your cameras used now, you see the only camera red LED is on. Please take this into account and do not use this as a criteria for camera status.
If you use fresh 0.2.3 S.L.P., both cameras should be enabled in config file by default (I mean stereopi.conf in a /BOOTpartition), but please check this too. You should have "video_mode=3D" in a second row.
I can suggest you have some mechanical issue, like not 100% connection on one of camera ribbons side. What I'm doing in a case like yours:
1. Try to run
If everything is Ok you will see this answer:
"supported=2" means system has found dt-blob.bin and understand, that there are two cameras support.
"detected=2" means both cameras are detected and answered to system request.
I can suggest you will see "detected=1", it means one camera is not detected.
2. Now you need to understand, which camera is not working.
For this you should poweroff your StereoPi, disconnect one camera, and either run "vcgencmd get_camera" or use "raspistill -cs ..." test.
3. When you found this camera, try two steps:
a) DIsconnect ribbon from undetected camera, and also from StereoPi. Connect them again, and try to test it.
b) Disconnect ribbon from undetected cam and the StereoPi, and connect it in opposite way. That is insert ribbon tail from the camera to the StereoPi, and the tail from the StereoPi to your camera. Run the tests.
Please share your results here!
/opt/StereoPi/stop.shSecond notice: built-in Raspbian stereoscopic mode support uses the only camera LED. That is while both your cameras used now, you see the only camera red LED is on. Please take this into account and do not use this as a criteria for camera status.
1. Try to run
vcgencmd get_cameraCode: Select all
supported=2, detected=2"detected=2" means both cameras are detected and answered to system request.
WillfordRockwell
I see:Realizator wrote: Sun Jul 28, 2019 12:16 pm 1. Try to runIf everything is Ok you will see this answer:Code: Select all
suported=2, detected=2And no image from cameras after 5 min.
config.conf is:
photo_resolution=default
video_width=1280
video_mode=3D
video_height=720
video_fps=30
video_bitrate=3000000
video_profile=baseline
rtmp_url=
rtmp_enabled=0
mpegts_clients=192.168.1.10:3001
mpegts_enabled=0
rtsp_enabled=0
usb_enabled=1
audio_enabled=0
video_wb=auto
exposure=auto
contrast=-15
sharpness=0
digitalgain=0.0
wifi_iface=wlan0
wifi_ssid=RT-GPON-2692
wifi_psk=DELETED
record_enabled=1
record_time=300
dec_enabled=0
up_down=0
swapcams=0
udp_clients=192.168.1.10:3000
udp_enabled=0
ws_enabled=1
PID TTY TIME CMD
1 ? 00:00:02 systemd
2 ? 00:00:00 kthreadd
4 ? 00:00:00 kworker/0:0H
5 ? 00:00:00 kworker/u8:0
6 ? 00:00:00 mm_percpu_wq
7 ? 00:00:00 ksoftirqd/0
8 ? 00:00:00 rcu_sched
9 ? 00:00:00 rcu_bh
10 ? 00:00:00 migration/0
11 ? 00:00:00 cpuhp/0
12 ? 00:00:00 cpuhp/1
13 ? 00:00:00 migration/1
14 ? 00:00:00 ksoftirqd/1
16 ? 00:00:00 kworker/1:0H
17 ? 00:00:00 cpuhp/2
18 ? 00:00:00 migration/2
19 ? 00:00:00 ksoftirqd/2
20 ? 00:00:00 kworker/2:0
21 ? 00:00:00 kworker/2:0H
22 ? 00:00:00 cpuhp/3
23 ? 00:00:00 migration/3
24 ? 00:00:00 ksoftirqd/3
26 ? 00:00:00 kworker/3:0H
27 ? 00:00:00 kdevtmpfs
28 ? 00:00:00 netns
29 ? 00:00:00 kworker/0:1
31 ? 00:00:00 kworker/1:1
32 ? 00:00:00 kworker/3:1
33 ? 00:00:00 khungtaskd
34 ? 00:00:00 oom_reaper
35 ? 00:00:00 writeback
36 ? 00:00:00 kcompactd0
37 ? 00:00:00 crypto
38 ? 00:00:00 kblockd
39 ? 00:00:00 watchdogd
40 ? 00:00:00 rpciod
41 ? 00:00:00 xprtiod
44 ? 00:00:00 kswapd0
45 ? 00:00:00 nfsiod
55 ? 00:00:00 kthrotld
56 ? 00:00:00 iscsi_eh
57 ? 00:00:00 dwc_otg
58 ? 00:00:00 DWC Notificatio
59 ? 00:00:00 vchiq-slot/0
60 ? 00:00:00 vchiq-recy/0
61 ? 00:00:00 vchiq-sync/0
62 ? 00:00:00 vchiq-keep/0
63 ? 00:00:00 SMIO
65 ? 00:00:00 mmcqd/0
66 ? 00:00:00 jbd2/mmcblk0p2-
67 ? 00:00:00 ext4-rsv-conver
69 ? 00:00:00 ipv6_addrconf
90 ? 00:00:00 systemd-journal
95 ? 00:00:00 kworker/u8:2
109 ? 00:00:00 kworker/2:2
131 ? 00:00:00 systemd-udevd
187 ? 00:00:00 cfg80211
259 ? 00:00:00 systemd-timesyn
305 ? 00:00:00 thd
307 ? 00:00:00 avahi-daemon
309 ? 00:00:00 systemd-logind
314 ? 00:00:00 dbus-daemon
335 ? 00:00:00 dhcpcd
337 ? 00:00:00 avahi-daemon
345 ? 00:00:00 cron
364 ? 00:00:00 php-fpm7.0
377 ? 00:00:00 run.sh
397 ? 00:00:00 RTW_CMD_THREAD
401 ? 00:00:00 dnsmasq
423 ? 00:00:00 sshd
467 ? 00:00:00 php-fpm7.0
468 ? 00:00:00 nginx
469 ? 00:00:00 php-fpm7.0
470 ? 00:00:00 nginx
471 ? 00:00:00 nginx
472 ? 00:00:00 nginx
473 ? 00:00:00 nginx
506 tty2 00:00:00 fbi
507 ? 00:00:00 wlan-switch.php
508 ? 00:00:00 video-source.sh
509 ? 00:00:00 loop-mpegts.sh
510 ? 00:00:00 loop-mpegts-sky
511 ? 00:00:01 loop-rtmp.sh
512 ? 00:00:01 usb-video.sh
513 ? 00:00:00 loop-record.sh
514 ? 00:00:00 record-watcher.
515 ? 00:00:00 loop-ws.sh
516 ? 00:00:05 skybox-server.j
519 ? 00:00:06 index.js
520 ? 00:00:00 raspivid
521 ? 00:00:00 splitter
539 ? 00:00:01 stereopi
616 ? 00:00:00 wpa_supplicant
643 ? 00:00:00 dhclient
952 ? 00:00:00 kworker/0:1H
953 ? 00:00:00 kworker/1:1H
954 ? 00:00:00 kworker/2:1H
955 ? 00:00:00 kworker/3:1H
2546 ? 00:00:00 kworker/0:0
2620 ? 00:00:00 kworker/1:0
4205 ? 00:00:00 kworker/3:0
4369 ? 00:00:00 kworker/0:2
4486 ? 00:00:00 kworker/1:2
4923 ? 00:00:00 kworker/2:1
4966 ? 00:00:00 sshd
5010 ? 00:00:00 systemd
5013 ? 00:00:00 (sd-pam)
5023 pts/0 00:00:00 bash
6172 ? 00:00:00 sleep
6181 ? 00:00:00 recorder
6217 ? 00:00:00 sleep
6218 ? 00:00:00 sleep
6219 ? 00:00:00 sleep
6222 ? 00:00:00 sleep
6223 pts/0 00:00:00 ps- Realizator
Your config files are correct.
While first boot S.L.P. image formats all free space on your micro SD to FAT 32. If you are using a very big micro SD card, it might take some time. But, as a rule, it is not a 5 minutes like in your case.
"detected=2" means cameras answers to the system requests by I2C. But actually I2C uses only 2 lines from 15 lines available in the camera ribbon. It means that some data line possibly has bad connection on camera side or StereoPi side. Usually "disconnect-connect" solves this issue.
WillfordRockwell, try to do cameras reconnection, and also plan "b" in my comment (reverse connection).
Before doing this please check, that tiny brown connectors on both camera boards are sitting firmly. I mean connectors at the end of a flexible cable, which is running from black optics boxes to green PCB of your camera (correct for V1 cameras).
If this will not help, it is better to use desktop-edition of Raspbian for future debug. You can use our OpenCV image as is, or any stock-new Raspbian with dt-blob.bin added to /BOOT partition.
After this you can test cameras one-by one, and find one with a bad behavior.
Connect one camera and test it alone. Then disconnect it, connect second camera and test it again.
May be this is a ribbon issue. If you own Starter or Deluxe kit, you have additional short camera ribbons. You can try to replace current ribbon with a new one to localize your issue.
