Hi iPutBack,
I have no DK2 nearby to test, so I can't confirm the settings. Did you happen to try to test this config using regular Raspberry Pi 4? (Pi3 is not good, but RPi4 has the same CPU as CM4).
ENOSPC means insufficient video memory; you can try to increase GPU MEM in config.txt Also, did you stop SLP2 scripts over console before doing raspistill?
By the way, which StereoPi do you have? I guess it's V2 with CM4 (due to "dtoverlay=dwc2,dr_mode=host" in your config file).
A few notes on your settings:
NOTE 1:
hdmi_timings=1080 1 33 10 15 1920 1 1 1 13 0 0 0 75 0 165000000 3
If you look at hdmi_timings section here
https://www.raspberrypi.com/documentati ... g_txt.html, you can find that in your case:
<h_active_pixels> = 1080 horizontal pixels (width)
<h_front_porch> = 33 horizontal forward padding from DE active edge
<h_back_porch> = 15 horizontal back padding from DE active edge
<v_active_lines> = 1920 vertical pixels height (lines)
<v_front_porch> = 1 vertical forward padding from DE active edge
<v_back_porch> = 13 vertical back padding from DE active edge
<frame_rate> = 75
<pixel_freq> = 165000000
So:
<pixel_freq> = (<h_active_pixels>+<h_front_porch>+<h_back_porch>) * (<v_active_lines>+<v_front_porch>+<v_back_porch>) * <frame_rate> =
(1080+33+15) * (1920 + 1 + 13) * 75 = 1128 * 1934 * 75 =
163616400
And you have
165000000. In my experiments with other custom HDMI screens, this parameter ruined the output if miscalculated.
If you are not sure which data to use, download EDID using
/opt/vc/bin/tvservice -d edid.dat; /opt/vc/bin/edidparser edid.dat (
details). This trick helped me a lot with custom HDMI screens.
NOTE 2:
Looks like DK2 has not the 1920x1080, but 1080x1920 resolution. This mobile-like screen orientation ruined
one of our first experiments. The screen rotation decreases FPS a lot. I see "display_rotate=3" in your settings, it means you try to rotate it. Technically it will work, but with artefacts and low FPS.
BTW "display_rotate" is
deprecated...
NOTE 3:
Our search of horizontally oriented screen led us to
this item. Yes, it's bulky and need a 3D printed case, as well as
plastic gear with lenses like this one. But it finally works with custom settings and resolution 1440x1440 per eye, or 2880x1440 as the total HDMI output resolution.
- IMG_6655.jpeg (2.81 MiB) Viewed 57131 times
