cameras not detected
Posted: Tue Jun 14, 2022 1:42 pm
by kivlerton
I'm setting up the StereoPi v2 Camera Kit using the Quick Start Guide and I'm having trouble getting a connection and stream from the cameras. I've only been able to detect 1 using get_camera
root@stereopi:~# vcgencmd get_camera
supported=2 detected=1
using raspivid -cs the output is
root@stereopi:~# raspivid -cs 0
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
root@stereopi:~# raspivid -cs 1
mmal: Cannot read camera info, keeping the defaults for OV5647
mmal: Could not select camera : error 3
viewing the gui at stereopi.local there is no video stream but the menu options are there
When using raspistill-v -o test.jpg I get this output
root@stereopi:~# raspistill -v -o test.jpg
"raspistill" Camera App (commit 0093675e4aa6 Tainted)
Camera Name imx219
Using camera 0, sensor mode 0
GPS output Disabled
Quality 85, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Time delay 5000, Timelapse 0
Link to latest frame enabled  no
Full resolution preview No
Capture method : Single capture
Preview Yes, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Flicker Avoid Mode 'off'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
When i plug each camera into my Pi0w I get the same mmal error when using raspistill. On the Pi0w, both cameras are detected but cannot take a photo like I can with my raspberry pi camera v2.
Connecting 2 x raspberry Pi camera V2 to the stereoPi gives, Cams detected 0, supported 2 in the camera settings of stereopi.local.
running the raspivid -cs 0 and raspivid -cs 1
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
mmal: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
Any help would be appreciated, thank you
Re: cameras not detected
Posted: Mon Jun 20, 2022 9:24 am
Hi kivlerton,
According to your error messages I guess the issue is the ribbon cable connection. Please check that cameras are connected correctly.
(btw, it is better to use "raspistill" command but not "raspivid" for tests)
Could you please share a photo of the camera with the ribbon inserted?
As for the Pi0w tests - am I got you right that you can take images using your V2 camera, but can't do this using cameras from the kit? Could you please tell me the OS you are using?
p.s. 'ENOSPC' error usually means two things. It's either lack of GPU memory, or poor connection of one of the line in the ribbon cable.
Posted: Mon Jun 27, 2022 2:56 pm
by kivlerton
Thanks for your response. Excuse my delayed response, I was on a work trip. Here is a photo of connected cables in the camera
I'd tried 6 different ribbons and none had worked. The ethernet lights no longer light up and i cannot connect to the device using ethernet or wifi.
I think the os for the pi0 was bullseye
Update:
I unplugged the pi4 compute module and reset it in position, this brought back the wifi and ethernet, and 2 cameras are now being detected. My installing of the pi4 module was bad. I still have a black screen in stereopi.local but 2 cameras are being detected. I'll play around a bit more and see if i can get it going
Posted: Fri Jul 01, 2022 5:26 pm
Uh, it was the CM4 installation. Yup, installing it up to the sensible "click" is crucial.
I'm glad it works for you now!
Posted: Wed Aug 17, 2022 7:27 am
by kivlerton
Yeah it certainly was my CM4 install. It was weird that the OS was loading and operating though. Thanks for your help
