2 inch LCD module & Antenna Instructions
I've been looking for instructions for installing the 2 inch LCD module and the antenna I received with the V2 kit but haven't found them- can anyone assist?
Re: 2 inch LCD module & Antenna Instructions
Hi lefsky,
The LCD guide instructions can be found here in our Wiki.
As for the antenna - we'll add this section soon too. The antenna settings are described in the CM4 datasheet, section 2.1
To say briefly, you can set the antenna option in the config.txt
To use an internal antenna add this parameter to the config.txt:
To use an external antenna add this parameter instead:
dtparam=ant1Code: Select all
dtparam=ant2Eugene a.k.a. Realizator
