1.44" TFT screen Waveshare
Other hardware discussion
I've got one of these tiny funny screens
So after following this manual with this fix I got this result:
Looks like new guides are coming :-)
stereomii
Re: 1.44" TFT screen Waveshare
Post by stereomii »
Realizator wrote: Fri Jun 21, 2019 12:51 pm I've got one of these tiny funny screens
Looks promising, although I think it will be difficult to package this nicely with my stereopi. Probably requires new case or add it to the outside of existing case with 14 soldered wires ;)
Jan a.k.a. stereomii
stereomii wrote: Tue Jun 25, 2019 12:30 pm Looks promising, although I think it will be difficult to package this nicely with my stereopi. Probably requires new case or add it to the outside of existing case with 14 soldered wires ;)
I'll try to do it solder-less, and will put my solution here. :-)
Realizator wrote: Wed Jun 26, 2019 10:52 am I'll try to do it solder-less
Lots of people use this kind of jumper wires for prototyping [first link, not a recommandation]
https://www.amazon.com/MCIGICM-40Pin-Br ... 07PLZC26F/
MauriceCyril
Post by MauriceCyril »
Hi everyone, is there an updated guide on how to set this screen up with the stereopi?
Hi MauriceCyril,
At the very beginning of this post there are two links for the manual with all the steps you need.
Do you have any problems while installing? Which Raspbian image you're using for that?
MauriceCyril
Thanks so much will check them out. I thought there was a new consolidated guide that I was missing.
Hi MauriceCyril,
You see, installation of this screen has no any problems, that's why we did not post any additional guides. The only difficulty I found was incorrect settings in the original guide, so I've posted second link to the RPi forum with the fix.
