PiSugar Support on StereoPi 2?
glowingskull
Post by glowingskull »
Has anyone attempted to use a PiSugar power supply with the StereoPi 2 board? https://github.com/PiSugar/PiSugar/wiki ... comparison
I know that the pogo pin connection method won't work for the StereoPi 2, since the CM4 covers the underside of the GPIO header, but I figure that can be worked around with creative soldering.
My questions are:
  • Can the StereoPi 2 accept power over the GPIO pins that PiSugar uses?
  • Does anything special need to be done for the I2C data channel that newer versions of the PiSugar use to talk to the Pi?
