PCB stackup detail for StereoPi v2
StereoPi v2 hardware questions
maes
Post by maes »
I'm working on a small adapter using the same HD-RA-DSF12-TR micro-HDMI connector as the StereoPi v2. Basically a 'super low profile' right angle adapter that would bring one of the Pi4's micro-hdmi ports to the same orientation as the usb and network ports.
Would you be willing to share details of the PCB stackup (# of layers, pcb thickness, etc) you used for the StereoPi v2 and where they're made?
Re: PCB stackup detail for StereoPi v2
Hi maes,
We used NexPCB company (https://www.nexpcb.com) and they did both PCB and assembly for us.
Here are the data you've asked about:
1 – L1_Top
2 – L2_Signal
3 – L3_VCC
4 – L4_GND
5 – L5_Signal
6 – L6_Bottom
L1. L1_Top ---------------------------------- 0.018 mm
0.150mm
L2. L2_Signal ---------------------------------- 0.018 mm
0.510mm
L3. L3_VCC ---------------------------------- 0.018 mm
0.150mm
L4. L4_GND ---------------------------------- 0.018 mm
0.510mm
L5. L5_Signal ---------------------------------- 0.018 mm
0.150mm
L6. L6_Bottom ---------------------------------- 0.018 mm
