Gstreamer Pipeline from Mac to Pi
phowe
Post by phowe »
Hello, I am continuing work on my VR display using a Raspberry Pi. After thorough testing, I have determined the Pi is not powerful enough to do the processing I need locally, so I have turned to Gstreamer. I want to stream the camera feed on the Pi to my Mac, process the camera feed on my Mac, and then stream the processed camera feed back to the Pi. I have gotten the first part to work without any issues, and I can display the processed camera feed on my Mac. However, I am not sure of the pipeline I need to use to send the processed camera feed back to the Pi to be viewed. I have tried searching the online forums, but I can only find examples for how to stream from a Pi to another Pi/to a computer. Any ideas on what the pipeline should be to stream from the Mac back to the Pi? Thank you in advance!
Code I am working with
Create video stream on raspberry pi:
raspivid -fps 40 -h 1088 -w 1920 -n -t 0 -0 - | gst-launch-1.0 -v fdsrc ! h264parse ! rtph264pay config-interval=1 pt=96 ! gdppay ! tcpserversink host=192.168.1.124 port=5000
Receive stream and process using OpenCV:
import cv2
import time
import numpy as np
from threading import Thread
class VideoGet():
    def __init__(self):
         self.cap = cv2.VideoCapture('tcpclientsrc host=192.168.1.124 port=5000 ! gdpdepay ! rtph264depay ! \
         decodebin ! videoconvert ! appsink', cv2.CAP_GSTREAMER)
         self.grabbed, self.frame = self.cap.read()
         self.stopped = False
    def start(self):
        Thread(target=self.get, args=()).start()
        return self
    def get(self):
        while not self.stopped:
            if not self.grabbed:
                self.stop()
            else:
    def stop(self):
        self.stopped = True
def BarrelDistortion():
    #define the distortion matrices here
def main():
    cap = VideoGet().start()
    gst_out = "appsrc ! videoconvert ! queue ! x264enc ! queue ! rtph264pay ! tcpserversink host=192.168.1.250 port=6000"
    out = cv2.VideoWriter(gst_out, cv2.CAP_GSTREAMER, 0, 40, (1920, 1088), True)
    frames=[]
    start = time.time()
    BarrelDistortion()
    while True:
        frame = cap.frame
        #apply the distortion to the frame, calling the processed frame dst
        out.write(dst)
        cv2.imshow("Test", dst)
        frames.append(dst)
        if cv2.waitKey(1) == 27:
            break
    cap.stop()
    out.release()
    cv2.destroyAllWindows()
    stop=time.time()
    print("FPS: ", str(len(frames) / (stop-start)))
if __name__ == "__main__":
    main()
Attempt to view video stream on the Pi:
gst-launch-1.0 -v tcpclientsrc host-192.168.1.250 port=6000 ! rtph264depay ! avdec_h264 ! video convert ! autovideosink sync=false
Error it throws:
ERROR: from element /GstPipeline:pipeline0/GstTCPClientSrc:tcpclientsrc0:
Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstTCPClientSrc:tcpclientsrc0:
streaming stopped, reason error (-5)
Re: Gstreamer Pipeline from Mac to Pi
Hi phowe,
As a rule, embedded systems usually do the output streaming, and your use case is a bit unusual.
Also, Python is not the best choice for video processing (especially for high resolution and simple things like barrel distortion).
I guess you need the low latency too (VR display) - in this case, using the TCP transport is not the best option, but this should work in the local network with the high bandwidth network. Since you have the "capture / encoding / outsreaming / receiving / decoding / undistorting / encoding / backstreaming / receiving / decoding / showing" queue, you'll get the additional at least the 0.3-0.5 seconds delay (or 1-1.5 seconds in reality).
If your main aim is an HDMI video output from the Pi camera without the barrel distortion, the best way is to use the OpenGL post-processing (or shaders) onboard. In this case, all heavy parts are done by means of Pi's GPU/VPU, and this works fine (but requires some programming skills).
phowe
Post by phowe »
Thanks so much for the response! I'll take it that you don't know of a proper pipeline to stream back to the Pi or why the error for the current pipeline is being thrown.
I ported the code to C++, but there was barely any performance gain since OpenCV is just a wrapper for C++ in Python. I also tried using the UDP protocol, but it was not working on my Wifi at home and I couldn't figure out why. I will try again since I moved back to college and have access to a different Wifi network. The latency isn't ideal, but it would at least allow me to stream 1080p at 30fps with barrel distortion applied, something I am nowhere near close to achieving natively on the Pi.
The main aim is to apply barrel distortion to the camera feed while maintaining 1080p at 30fps for the purposes of using it as a VR display. I would be open to using the OpenGL shaders to apply the distortion, but I cannot find any up-to-date examples on how to apply shaders. Most are a few years old and thus the dependencies and file locations have changed with the new versions of Raspian OS. If you have any links to current examples, could you please attach them?
Also, do you know if the GPU is powerful enough to apply a distortion at 1080p and maintain 30fps? Most examples I have found have been downscaled to 640x480, which is well below what I am seeking. If it's not, I don't really see the need to try the OpenGL shaders and instead will rely on Gstreamer or not applying a distortion at all.
On a sidebar, how much do you know about the new camera API, libcamera?
From my research, it appears to be based in the CPU rather than the GPU, which is what MMAL, Picamera, and the raspistill and raspivid applications were built on. Performance looks to be very similar due to hardware acceleration, but I have yet to test it myself. I'm wondering if using libcamera would allow for a performance boost using OpenCV since the data is already in the CPU and doesn't need to be copied over from the GPU. However, I don't know if this would help much since I know the arm CPU is the bottleneck with image processing as is and likely can't process 1080p regardless of if the data needs to be copied or not.
Hello phowe,
phowe wrote:
Tue Jan 11, 2022 9:14 pm
This is a regular network magic to figure out. You should have the single network (not mixed with other sub-networks or bridges), check "wifi clients isolation" settings on your router, etc. - too many potential issues to debug :)
The best article on digging out the OpenGL performance on Pi I found is this one. It has a lot of links to performance-related investigations.
You can take a look at the article I referenced above. In our own experience for VR implementation, we need a lot of image processing (distortion/undistortion, scaling, hemisphere-sphere texturing, FOV adjustment, etc.). It's hard to write all of this in the native code, so we used a "heavy" framework (Unity). As a result, our current approach is to do all that on the receiver's side (i.e. process by VR helmet, which is Oculus Gp/Q1/Q2 now in our case). As you guess, most mobile VR helmets have an advanced VPU for doing all that stuff. And we are using the most optimized Pi workflow (video capture/encoding), without GUI, to get the maximum of this part.
I didn't dig deep enough, since libcamera has no native stereoscopic support now and is useless for most of the "stereoscopy beginners". For advanced users it's fine (since you can access multiple cameras from the different processes and use hardware sync between cameras).
Well... maybe the very optimized approach can work for you. You see, RPi VPU has a specific ISP, extremely optimized for some operations. Under "optimization" I mean all hardware parts (including memory-optimized operations with no extra copying). One of these ISP features is "lens correction", used for the real-time fix of the image captured by the camera. You can fix a lot of aspects (color-related and distortion-related). I'm not sure it can be used for extreme distortion values, but you can play with it. You can use this post as an entry point to this scope :).
