Capturing video GStremer
Sencis
Post by Sencis »
Is there a way to capture (video0 & video2) with GStreamer in one pipeline?
This method displayed the image of only camera 2, it was expected that both images will be displayed together on the left and right, respectively.
" gst-launch-1.0 max-buffers=1 drop=true sync=false"
" v4l2src device=/dev/video"+ std::to_string(device_1) + " !"
" video/x-raw,"
" width=(int)" + std::to_string(capture_width) + ","
" height=(int)" + std::to_string(capture_height) + ","
" format=GRAY8,"
" framerate=(fraction)" + std::to_string(framerate) +"/1 !"
" appsink"
" v4l2src device=/dev/video"+ std::to_string(device_2) + " !"
" video/x-raw,"
" format=GRAY8,"
" appsink";
Sencis
Re: Capturing video GStremer
Post by Sencis »
it seems this is how it works
 " gst-launch-1.0 -e"
            " v4l2src device=/dev/video0 ! videorate !"
            " video/x-raw,"
            " width=(int)640,"
            " height=(int)400,"
            " format=GRAY8,"
            " framerate=(fraction)50/1 !"
            " m.sink_0"
            " v4l2src device=/dev/video2 ! videorate !"
            " video/x-raw,"
            " width=(int)640,"
            " height=(int)400,"
            " format=GRAY8,"
            " m.sink_1"
            " glvideomixer name=m sink_1::xpos=640 ! video/x-raw, width=(int)1280, height=(int)400, format=GRAY8, framerate=(fraction)50/1 !"
            " appsink max-buffers=1 drop=true sync=false";
Hi Sencis,
Am I got you right that you are using HDMI output and HDMI capture device to get video frames?
Sencis
Post by Sencis »
No, I am using two ov9281 csi-2 cameras. Link to the topic by cameras: https://forums.raspberrypi.com/viewtopic.php?t=325883
Uh, got you, thanx!
We've tried to use glvideomixer for bigger resolutions and color images, but the performance was poor. The idea was to find the workaround for the stereoscopic mode until the Bullseye new video subsystem fully supports it. Now we're still on Bullseye.
