Unreadeable recorded video in SLP
stereomii
Post by stereomii »
I wonder if I am the only one having problems recording videos with the SLP image. I mentioned it last year in viewtopic.php?p=252#p252 problems recording videos. Realizator suggested videos being not correctly closed.
Alas no real solutions came up. The problems continued what resulted in me losing interest in the StereoPi.
Recently I picked up StereoPi with a fresh SLP image (version 0.2.4), only to find out that no reliable video capture was possible. I tried to get some idea why and noticed that running /opt/StereoPi/run.sh in a ssh-terminal (after first stopping relevant processes with stop.sh) logged a lot of information on the termial screen.
Next lines seem to confirm that Gstreamer not correctly closing the recordings is indeed the reason why the recordings can not be played
Recording enabled
Recording without audio to  20200604-165655
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstQTMux:qtmux0: Could not multiplex stream.
Additional debug info:
gstqtmux.c(3391): gst_qt_mux_add_buffer (): /GstPipeline:pipeline0/GstQTMux:qtmux0:
Buffer has no PTS.
EOS on shutdown enabled -- waiting for EOS after Error
Waiting for EOS...
ERROR: from element /GstPipeline:pipeline0/GstUDPSrc:udpsrc0: Internal data stream error.
gstbasesrc.c(2950): gst_base_src_loop (): /GstPipeline:pipeline0/GstUDPSrc:udpsrc0:
streaming stopped, reason error (-5)
ERROR: from element /GstPipeline:pipeline0/GstQueue:queue0: Internal data stream error.
gstqueue.c(989): gst_queue_handle_sink_event (): /GstPipeline:pipeline0/GstQueue:queue0:
Need to stop recording
handling interrupt.
Interrupt: Stopping pipeline ...
Interrupt while waiting for EOS - stopping pipeline...
Execution ended after 0:00:28.678193959
Setting pipeline to READY ...
Recording parts by 30 seconds
Setting pipeline to NULL ...
Freeing pipeline ...
Recording stopped
So I tried to make sure Gstreamer (recorder) has time enough to shut down before a new recording is started. I modified /opt/SterePi/scripts/loop-record.sh by adding:
killall -q -INT recorder
sleep 2
before starting a new recording (after line 20)
    if [ "$record_enabled" = "1" ] ; then
		echo "Recording enabled"
	else
		sleep 1
		continue
    fi
#next two lines added:
     sleep 2
    if [ "$audio_enabled" = "1" ] ; then
		echo "Recording with audio"
And I am quiet delighted to see that there are almost no recording error anymore. (decreased from sometimes more than 50% to almost nothing)
So, after that I added a record button to the SLP, I will describe this in a new post.
Jan a.k.a. stereomii
Re: Unreadeable recorded video in SLP
Hi Stereomii,
Welcome back, we missed you here! :-)
Thank you for your catch! We'll test this approach. I also added this post to the list of improvements for the upcoming SLP update topic.
stereomii
Post by stereomii »
stereomii wrote:
Wed Jun 10, 2020 12:32 pm
.... And I am quiet delighted to see that there are almost no recording error anymore. (decreased from sometimes more than 50% to almost nothing)
I was a bit too optimistic :( . Recording long (>10 minutes) videos still give occasional unplayable files, although a lot less than it used to be :) .
May be on-the-go conversion from raw H264 to the readable MP4 is an issue. But raw264 is very uncomfortable for the viewing (no scroll, etc). We need to investigate this issue.
