Using StereoPi Lite with RPi 4B
guido167
Post by guido167 »
Hi all,
Completely new to the Raspberry Pi, but ordered the StereoPi Lite to be able to use stereo camera on Raspberry Pi 4B. Now I want to connect it, but see that you actually need the compute module. Is it also possible to use it with the Raspberry Pi itself? How do I set this up?
Thank you!
Re: Using StereoPi Lite with RPi 4B
Hi Guido167,
Actually StereoPi has a Raspberry Pi Compute Module as a heart. You can connect StereoPi to your RPi4, for example, by network. But for work you need a Compute Module installed in the StereoPi.
You can look at our short video video guides for the first steps with the StereoPi here:
https://wiki.stereopi.com/index.php?tit ... _tutorials
They might help you to understand next steps for your experiments.
jo96
Post by jo96 »
hi,
i have a pretty similar question. i would like to use a RaspberryPi 4 to control motors and sensors but i also want a stereo vision. So is it possible to use the stereoPi and connect it to the pi4 to send the stereo data?
jo96 wrote:
Tue Apr 28, 2020 1:00 pm
hi,
Some time ago we've posted an article about connecting the StereoPi over micro USB in ethernet mode. And in this post user Blinky occasionally tested right the thing you need - connecting the StereoPi to the RPi4 using this method. You can do it right this way, or use Ethernet cable for this.
jo96
Post by jo96 »
Realizator wrote:
Tue Apr 28, 2020 7:12 pm
hi,
Great, thank you!
Louise Morris
Post by Louise Morris »
Hi everyone,
Sorry to bring this conversation back to life.
I'd like to do a similar thing... Connecting the StereoPi to a raspberry pi 4 to stream stero Videos on YouTube. Is this possible with the pi 4 using the micro usb in ethernet mode to connect the StereoPi?
I'd like to do this because you cannot buy the raspberry pi CMR in the UK for the next 7 months!
Many thanks,
Louise
Louise, the short answer is no - it's impossible to use RPi4 instead of CM4. You can consider CM4 as a regular RPi4 with all connectors removed, reduced PCB, and a lot of special connectors exposed. So RPi4 is physically incompatible with the CM4 and can not be installed instead.
