I just start to use my stereoPi and the first think I would like to do is :
sudo apt-get update
Ign:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Ign:2 http://archive.raspberrypi.org/debian stretch InRelease
Err:3 http://archive.raspberrypi.org/debian stretch Release
Could not open file /var/lib/apt/lists/partial/archive.raspberrypi.org_debian_dists_stretch_Release - open (30: Read-only file system) [IP: 93.93.130.104 80]
Err:4 http://raspbian.raspberrypi.org/raspbian stretch Release
Could not open file /var/lib/apt/lists/partial/raspbian.raspberrypi.org_raspbian_dists_stretch_Release - open (30: Read-only file system)
Reading package lists... Done
W: chown to _apt:root of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (30: Read-only file system)
W: chmod 0700 of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (30: Read-only file system)
W: Not using locking for read only lock file /var/lib/apt/lists/lock
W: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.PYgw7i - IsAccessibleBySandboxUser (30: Read-only file system)
W: Problem unlinking the file /var/lib/apt/lists/partial/.apt-acquire-privs-test.UZyKf8 - IsAccessibleBySandboxUser (30: Read-only file system)
W: Problem unlinking the file /var/lib/apt/lists/partial/raspbian.raspberrypi.org_raspbian_dists_stretch_InRelease - PrepareFiles (30: Read-only file system)
W: Problem unlinking the file /var/lib/apt/lists/partial/archive.raspberrypi.org_debian_dists_stretch_InRelease - PrepareFiles (30: Read-only file system)
W: Problem unlinking the file /var/lib/apt/lists/partial/archive.raspberrypi.org_debian_dists_stretch_Release - PrepareFiles (30: Read-only file system)
E: The repository 'http://archive.raspberrypi.org/debian stretch Release' does no longer have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: Problem unlinking the file /var/lib/apt/lists/partial/raspbian.raspberrypi.org_raspbian_dists_stretch_Release - PrepareFiles (30: Read-only file system)
E: The repository 'http://raspbian.raspberrypi.org/raspbian stretch Release' does no longer have a Release file.
W: Problem unlinking the file /var/cache/apt/pkgcache.bin - RemoveCaches (30: Read-only file system)
W: Problem unlinking the file /var/cache/apt/srcpkgcache.bin - RemoveCaches (30: Read-only file system)
