I decided to add a physical button on it to take photographs.
The idea is simple : A script launched at startup waits for the button and than call the SLP "make_photo" page as if we pressed the icon on the web interface. (Need SLP with such photo icon in the interface, I use version 0.2.3)
To do so, I added a script in /opt/StereoPi/scripts/button.py (which does the job mentionned) and stated it in /opt/StereoPi/run.sh with "./scripts/button.py &".
Here is the script if you want to reproduce:
#!/usr/bin/env python
# Configuration
button = 3
# Imports
import RPi.GPIO as GPIO
from time import sleep
from urllib2 import urlopen
# Setup
GPIO.setmode(GPIO.BCM)
GPIO.setup(button, GPIO.IN, pull_up_down=GPIO.PUD_UP)
# Wait button loop
while True:
GPIO.wait_for_edge(button, GPIO.FALLING)
print "Shoot!"
urlopen('http://localhost/make_photo.php')
sleep(0.5)
Edit: the python script should have execution permissions for this way to work (see messages below)
