V2 (IMX219) camera module and SLP UDP stream?
mcesh
Post by mcesh »
Hi, I'm new to the StereoPi and just testing it out on the bench. I've got the deluxe kit and have been able to get one and two simultaneous streams going from the included cameras using the SLP image via UDP to Ubuntu 16.04 using gstreamer. However, I have a couple raspberry pi v2 camera modules (IMX219 sensors) with wide-angle lenses that I want to test, but so far if I plug one in, I can't get any video, and if I try taking a still using the stereopi.local web interface, the image link is 404. Is there something I need to do to get them working? I haven't yet had a chance to connect the Pi to HDMI to see if they are working locally.
For reference the gstreamer command I'm using is
gst-launch-1.0 -v udpsrc port=3000 buffer-size=300000 ! h264parse ! avdec_h264 ! autovideosink sync=false
Thank you!
Re: V2 (IMX219) camera module and SLP UDP stream?
Hi mcesh,
If you have a couple of classic V2 cameras like these
and install both instead of cameras from your Deluxe kit, they should work without any additional settings.
You mentioned "but so far if I plug one in". You need to connect them both. If you connect one V2 camera and one V1 camera, system will have a problem (as under the hoot Raspbian use different drivers for them).
If you connect the only one camera, you need to set "2D" mode in admin panel.
Am I right understand you, that you use a classic V2 cameras with wide-angle extension like this one?
(you can read our article related to wide-angle V2 cameras here in our blog)
If yes - they should work out of the box too.
Another point - you can use a special edition of wide angle V2 cameras from Soho Enterprise, like these:
In this case you need a special edition of dt-blob for these cameras to work.
And the last notice.
If you have access to admin panel, you can go to the web-based bash:
(we described how to use it in this article)
So you can stop our scripts (/opt/StereoPi/stop.sh) and look, how system see your cameras, typing a command
vcgencmd get_camera
This command will show you two numbers - "supported" and "detected" cameras. If your "detected" number is not 2 but 0, it means you need to check the connection. Please share your results here.
mcesh
Post by mcesh »
I had multiple issues:
- I had only the single V2 camera connected but 3D selected.
- I connected a second V2 camera and set 3D, and it still didn’t work. I ran the commands in the console and found supported = 2 connected = 1. I then set it to 2D mode and checked swap camera, and got video! It turned out the first camera was bad, and replacing it allowed me to get 3D.
FWIW, I am using Blue Robotics cameras (now discontinued), that are a V2 module with wide angle lens installed.
Thank you for your help!
Hi Mcesh,
I'm glad it works for you now!
By the way, what project you're planning to do with the StereoPi? ;)
Taki
Post by Taki »
Tue Feb 18, 2020 7:38 am
I'm quite late but what kind of special edition of dt-blob is needed for the wide angle V2 cameras and where can I find it? I used the one for CM3/CM4 from here https://wiki.stereopi.com/files/dt-blob.bin.zip but while I get "supported=2 detected=2" when I enter vcgencmd get_camera, raspistill crashes with the widely known ENOSPC error:
I've tried with up to 256 MB memory for GPU but it didn't work, so I thought it may have something to do with the dt-blob.
[I'm using StereoPi V1 and this an experiment to see it these cameras also show the magenta tint as these [viewtopic.php?f=5&p=3233#p3233/
Any help would be appreciated.
Taki, could yoiu please define which model of the camera you are using?
The photo you've quoted has SE-SB01 cameras from Soho Enterprise (one of early prototypes), and needs a special dt-blob.bin
I will be pleased to help you with dt-blob after getting your camera model info :-)
Taki
Post by Taki »
I'll provide more information after my vacation. ;-)
Wow, Taki, have a good rest! :-)
Taki
Post by Taki »
Thu Sep 08, 2022 9:00 am
Hi Eugene!
The cameras I have are ov5647 and as of today they work. If all problems go away in my vacations, I need more of them :lol:
Now I'll have to wait for some sunny days to see if I get the magenta tint or not.
Cheers,
Taki
Hi Taki,
Well, I have to check your way of fixing issues.
If this vacation trick proves its stability, I will add this to the Wiki! ;-)
