No camera feed visible and only one Camera LED illuminated
Posted: Sat Feb 29, 2020 11:48 pm
I've read through all of the forum entries on camera issues, but none have the exact same parameters. Regardless, I've tried those steps outlined in other forum entries to no avail.
Hardware: StereoPi Starter Kit with provided microSD. All hardware used is what was supplied with zero substitutions.
General Symptoms: Device boots and displays white StereoPi logo. System is accessible and interactive at: http://stereopi.local/update.html, but with no camera feeds available. Console at http://stereopi.local/update.html is functional.
BLUF: Only one camera socket on the StereoPi seems to be functioning. I have swapped cameras back and forth between the two sockets upwards of seven times. Only one camera LED illuminates at one time. When cameras are swapped, the opposite camera LED illuminates. This ties it to the specific socket and rules out a camera issue.
On the console, typing "raspistill -cs 0" or "raspistill -cs 1" yields:
However, the subsequent troubleshooting step of "vcgencmd get_camera" yields:
supported=2 detected=2
As aforementioned, I've swapped cameras numerous times, taking care to blow out the socket and seat the cable properly. I know the first solution will be concerning the cable seating, however I emphasize that one socket works every time, so technique is not the limiting factor. Thank you for your time and assistance.
