StereoPI V2 - how to trigger a flash light?
Posted: Mon Mar 29, 2021 4:56 pm
I ordered StereoPI V2, and I want to be well prepared if shipment arrives .
Since I want to use the StereoPI V2 only for still images I need a flash for low light situations.
Is there any way to trigger a flash?
Typical flash shoes have one middle contact which is to pull to ground to trigger the flash. Can I do that with an GPIO of StereoPI V2?
Since it is necessary that flash fires if both cams have shutter open the timing is key. Can the flash trigger timepoint be adjusted by software?
Thanks...
Thanks...
