StereoPi works too slowly
Posted: Fri Jan 15, 2021 4:29 pm
Hi, we have a term project that we need to use StereoPi. Because of the pandemic, we try to connect StereoPi via TeamViewer. One of our TA helped us with the StereoPi connections. In the first picture, you can see the connections of StereoPi. StereoPi is connected to a raspberry pi board via USB cable.
After connections are all made we can see the interface down below.
To check if cameras are working fine we try to compile 1_test.py based on the instructions inside the shared video. (https://www.youtube.com/watch?v=wllLrNU ... =emb_title)
Unlike in the video, the process performed in our experiment is stuck as in the photo down below.
We started to suspect that cameras might be not working but after a few tryouts, we manage to acquire some images.
Also as can be seen from the last three images when we try to change the place of the window it leaves a mark on the screen.
We are pretty new to forums and StereoPi so we will be grateful for any help:)
