Camera 1 not detected
Posted: Fri Oct 16, 2020 9:46 pm
by ammarburg
Hi all,
I feel bad using the forum as a help ticketing system, but seems to be the way to go.
I have a v0.9 Stereopi from the original CrowdSupply buy which I'm finally trying to get going. I have tried both the v0.2.3 SLP and a current Raspbian install with the dt-blob. Cameras in all cases are Raspi Cam V2 NOIR,
In both cases:
1. "vcgencmd get_camera" returns "supported=2 detected=1"
2. "raspistill -cs 0 -v" appears successful, "raspistill -cs 1 -v" returns:
3. I've swapped the (camera+cable) sets and had the same behavior.
Further options for debugging?
Many thanks, everyone.
Re: Camera 1 not detected
Posted: Sun Oct 18, 2020 12:28 pm
Hello ammarburg ,
Yes, the forum is the right place to go :-)
Sorry for this issue with your board. I see you did a lot of troubleshooting steps. If you have this error with the "-cs 0" option in both cases (before and after camera swap), then it looks like a second CSI-2 connector issue. I can suggest you a board replacement.
I sent you an email (to the address you used to register on this forum). Please answer.
Posted: Fri Oct 23, 2020 4:56 am
by ammarburg
Hi Eugene,
Just confirming I replied to the email earlier this week. Let me know if it didn't come through.
Posted: Fri Oct 23, 2020 9:28 am
Hi ammarburg,
Replacement confirmed by Crowd Supply, and they will ship it to you in a few days!
I also replied to your email.
Posted: Sat Nov 07, 2020 5:57 am
by ammarburg
Hate to harp on this, but I have not had any communication from Crowd Supply. Is a replacement still in the works?
Thanks!
