Stereo Localization
HASSAN MEHMOOD
Stereo Localization
Post by HASSAN MEHMOOD »
Greetings,
can we do localization using stereo Pi with the help of following links ?
1-https://github.com/introlab/rtabmap/wiki/Stereo-mapping
2-http://wiki.ros.org/rtabmap_ros/Tutoria ... eldMapping
Re: Stereo Localization
Hi Hassan,
Yes, you can. But, afaik, this algorithm needs a lot of computation power, and might not be real-time on the Raspberry Pi. I think that Octomap approach is more acceptable for the real-time processing on RPi (this fact is mentioned here).
HASSAN MEHMOOD
ok, Sir can I have a blog from you regarding localization using octomap please ?
It will be very beneficial for me in my research.
Thank you
HASSAN MEHMOOD wrote:
Tue May 05, 2020 12:08 pm
Thank you
Hello Hassan Mehmood,
We have a plans to do this, but not in the nearest time, as we have a queue with upcoming projects... If Octomap guides for ROS doesn't works for you?
HASSAN MEHMOOD
ok Sir, I am trying to implement this localization technique, lets see how can I get this.
Thank you
