Cases, camera mount mechanics, 3D printing, laser cut etc.
NiamoR42
Post
by NiamoR42 » Wed May 22, 2019 8:31 pm
perhaps it could help you : I did some modifications on the current stereoPi case.
you can find the cad and freecad project here :
https://www.thingiverse.com/thing:3633970
I remove these volumes on the current design :
result (I have to improve my 3D printer...) :
You are able to use screw & bolt to fix the card =)
NiamoR42
Post
by Realizator » Thu May 23, 2019 9:49 am
NiamoR42, wow, that's great, thank you for sharing!
By the way, are you planning to add vent holes at the bottom, or you have no temperature issues? Are you using CM3 or CM3+?
NiamoR42
Post
by NiamoR42 » Thu May 23, 2019 11:10 am
Realizator wrote: ↑Thu May 23, 2019 9:49 am
why not, I'll see it by using the stereoPI.
it's true that the glue gun was good but, with the temperature, the cover takeoff. I may need to use others screw.
