Validation of a pressure sensor shoe sole using two StereoPi boards
Posted: Tue Nov 09, 2021 2:04 pm
by alexandrialeer
Hello!
For my project work at the university, I have used the as described in the blog post
described in the blog post. It works very well so far, I use the synchronisation of the boards via the GPIOs. The camera system is supposed to record the gait cycle of a human being in order to compare the data of a pressure sensor shoe sole with the camera images. However, the given c-programme only triggers a photo. My goal is to take several pictures per second to map the gait cycle well. If I change the arguments in the raspistill command as follows:
execl("/usr/bin/raspistill","/usr/bin/raspistill", "-s", "-t","1000","-tl","0", "-3d", "sbs", "w", "5184", "-h","1944","-o", pattern, NULL);
and then run de c file, 3fps is recorded.
Unfortunately, the problem arises that I can no longer trigger the cameras in the terminal, although -Photo STDIN !\n"- is printed, no new photos are triggered, the same problem when triggering the photos using the Python file for synchronisation.
I guess it's because of the GPIOs, but I don't know enough about them to modify the script accordingly.
I also replaced the raspistill command with the raspivid command, with the aim of recording synchronised videos. But the same problems occur. :roll:
Maybe someone who knows the system better can help me. Thanks in advance ;)
The c-code as file here: https://stereopi.com/sites/default/file ... opi_sync.c
The py-code as file here:
#!/usr/bin/env python3
# Import libraries
import RPi.GPIO as GPIO
# Config
pin_notation = GPIO.BCM
trigger_pin = 4
# Setup
GPIO.setmode(pin_notation)
GPIO.setup(trigger_pin, GPIO.IN)
# Trigger pin
GPIO.setup(trigger_pin, GPIO.OUT)
GPIO.output(trigger_pin, GPIO.LOW)
# Cleanup at exit
GPIO.cleanup()
