wi-fi only 2Mb/s ?
zoldaten
wi-fi only 2Mb/s ?
Post by zoldaten »
hi.
i go on with my stereopi - https://habr.com/ru/post/573986/
But have a little trouble.
How to speed up a wifi ?
I use usb stick with good speeds which work in 5Ghz and 2,4Ghz. So i use 5Ghz for a moment.
More over i use stand alone router tp-link AX3000.
With iwconfig i see that the link possible with 434Mb/s but SLP image shows only 2Mb/s
How to change that ? Is it possible ?
Re: wi-fi only 2Mb/s ?
Hey Zoldaten,
If you are talking about the SLP2 - it shows you the current video bitrate, but not the WiFi speed. You can change the video bitrate in settings.
zoldaten
Post by zoldaten »
Tue Sep 14, 2021 9:32 pm
Hey Zoldaten,
i`m still with stereopi V1. Whats the best bitrate for it ?
Can`t remove artifacts on videosteam. Used to think that it was a result of bad wi-fi and/or bad usb dongle.
But after that i replaced everything, tried 2.4 and 5Ghz i suppose is not.
p.s.thanks for quick reply )
