I upgraded via sudo apt-get update && sudo apt-get upgrade the stereopi (v0.23) img but I have some issues. Probably I shouldn't have done this...
![Sad :(](./images/smilies/icon_e_sad.gif)
After the upgrading process I had some issues with the package php7.0-fpm: via browser stereopi.local aswered Bad gateway. So I solved with sudo apt-get purge php7.0-fpm && sudo apt-get install php7.0-fpm.
Now stereopi.local page work fine again: I can see the StereoPi logo and click the different bottons but no stream video incoming as if browser stream option had disabled (instead it is enable); connectng the StereoPi via HDMI both camera images are freezed to the first image arrived to the system.
I post below some Debug test made I don't know if there are correlation between the php7.0-fpm issue and this:
via browse (web developer console F12)
WebSocket connection to 'ws://stereopi.local:8080/' failed: Error in connection establishment: net::ERR_CONNECTION_REFUSED
via console
/usr/bin/nodejs ./wsstream/index.js 1280 720 30
module.js:549
throw err;
Error: Cannot find module '/wsstream/index.js'
at Function.Module._resolveFilename (module.js:547:15)
at Function.Module._load (module.js:474:25)
at Function.Module.runMain (module.js:693:10)
at startup (bootstrap_node.js:188:16)
at bootstrap_node.js:609:3
So does anyone have any idea or suggestions about it?
Thanks in advance
