	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/973" />
	<updated>2020-06-22T13:54:07+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/973</id>
		<published>2020-06-22T13:54:07+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2094#p2094</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2094#p2094"/>
		<title type="html"><![CDATA[Re: IP address for StereoPi on Linux (Ubuntu 20.04)]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2094#p2094"><![CDATA[
(this quick answer is not elaborated and without checking, but it may help you)<br><br>On Linux, the .local domain naming is done with mdns / zeroconf / avahi (three terms for your searches).<br>Perhaps that the service is not running or the configuration is not working on your system. Note: I do not know it well.<br><br>The router I have also intercepts this name and creates a stereopi.home address.<br>Some routers allow to set a fixed IP by DHCP based on the MAC address, and some even to attribute a DNS to it.<br>Alternatively, you can probably replace the DHCP request by a static IP in the StereoPi (search for a tutorial for Raspbian, but not a graphical one)<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=101">stereomaton</a> — Mon Jun 22, 2020 1:54 pm</p><hr />
		<author><name><![CDATA[KevinMoerman]]></name></author>
		<updated>2020-06-21T07:57:00+00:00</updated>
		<published>2020-06-21T07:57:00+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2093#p2093</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2093#p2093"/>
		<title type="html"><![CDATA[IP address for StereoPi on Linux (Ubuntu 20.04)]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2093#p2093"><![CDATA[
To date the instructions for StereoPi appear to focus on MacOS and WIndows. It would be great if some basic instructions for Linux users could be added. <br><br>The first point is connecting to the StereoPi over the network. For MacOS and Windows it says to connect to:<br><a href="http://stereopi.local" class="postlink">http://stereopi.local</a><br>However as mentioned it does not work on Linux. <br><strong class="text-strong">Question:</strong> Why does this not work on Linux? Can you make it work? I have a project with my kids for a wildlife camera (<a href="https://mynaturewatch.net/daylight-camera-instructions" class="postlink">https://mynaturewatch.net/daylight-camera-instructions</a>) where they do have a system where stuff can successfully stream on a link like this. Can this be made to work for StereoPi? <br><br>I then followed the alternative steps to scan the network to find the IP address of the device. On Ubuntu I used: <div class="codebox"><p>Code: </p><pre><code>sudo arp-scan -l | sort</code></pre></div>From the output I found this to be the StereoPi: <br>192.168.1.71c:bf:ce:bf:4f:43Shenzhen Century Xinyang Technology Co., Ltd<br><br>This works in principle but I've noticed the IP address may change (it changed on me when I had to power down and power up the SteroePi). <br><strong class="text-strong">Question:</strong> Can a static IP address be set so it does not change? Again the mynaturewatch project also has a static IP it seems.<br><br>Thanks.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=475">KevinMoerman</a> — Sun Jun 21, 2020 7:57 am</p><hr />
