	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/916" />
	<updated>2021-08-17T02:25:00+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/916</id>
		<author><name><![CDATA[AaronD123]]></name></author>
		<published>2021-08-17T02:25:00+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2779#p2779</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2779#p2779"/>
		<title type="html"><![CDATA[Re: Connecting stereopi to two displays?]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2779#p2779"><![CDATA[
Using a splitter, isn't the total number of pixels/second across both displays (left eye + right eye) limited to what the Pi can push out of a single port?  So a port-maximum of 1920x1080x60Hz means that I can't have a dedicated 1920x1080x60Hz screen for each eye?<br><br>It *could* however, be 1920x1080x30Hz for each eye, while the Pi runs at 60Hz, if the graphics driver and the splitter both work that way: odd full-frames to one eye, even full-frames to the other.  Or side-by-side, but that guarantees a weird aspect ratio somewhere, either out of the single port, or into each eye.<br><br>---<br><br>It seems to me that the "standard" solution of using a single output and splitting it, was originally to solve a problem that no longer exists today.  Or at the very least, doesn't have to exist *here*.  (I'll make a concession for a phone-based VR headset, as it still requires the side-by-side single-screen solution.)  But why continue to require that solution with dedicated, purpose-designed hardware?  Since the Pi4 and CM4 both have dual HDMI outputs, why not send a camera to each in 2D full screen?  (plus possibly an application-specific overlay)<br><br>I know it would require a StereoPi v3 to bring out the second port, when the v2 is only a year old, but for someone just entering the 3D video and augmented vision space, it seems SO much more straightforward to just plug the two glasses-mounted retinal-projectors into their two connectors like you do for the cameras, and declare the hardware to be done.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=951">AaronD123</a> — Tue Aug 17, 2021 2:25 am</p><hr />
		<author><name><![CDATA[MWaddell]]></name></author>
		<updated>2020-04-28T17:58:02+00:00</updated>
		<published>2020-04-28T17:58:02+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1907#p1907</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1907#p1907"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1907#p1907"><![CDATA[
Thanks, this is actually really helpful. I really just need the board that splits the images into two separate screens - I can figure out how to connect the displays I linked to it fairly easily I would think. I'll keep the forum posted!<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=383">MWaddell</a> — Tue Apr 28, 2020 5:58 pm</p><hr />
		<updated>2020-04-27T09:30:07+00:00</updated>
		<published>2020-04-27T09:30:07+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1900#p1900</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1900#p1900"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1900#p1900"><![CDATA[
Usually for the VR applications (like helmets) it is used a couple of screens (for each eye), but with a single HDMI input, like this:<br><a href="https://imall.com/product/90HZ-VR-LCD-screen-display-3.81-inch-OLED-AMOLED-dual-1080-1200-TF38101A-HDMI-to-MIPI-board-For-DIY-3D-Glasses/Cellphones-Telecommunications-Mobile-Phone-Parts-LCDs/aliexpress.com/32916485500/568-294047/ru" class="postlink">https://imall.com/product/90HZ-VR-LCD-s ... -294047/ru</a><br>Or round screen (magic leap?) like this: <a href="https://imall.com/product/Wisecoco-Real-AMOLED-Display-1.39-inch-Round-Circle-Circular-OLED-LCD-Module-Screen-400-with-HDMI-MIPI-Interface-RM69080/Computer-Office-Tablet-Accessories-LCDs-Panels/aliexpress.com/32973389372/567-9225940/ru" class="postlink">https://imall.com/product/Wisecoco-Real ... 9225940/ru</a><br>You can find more options by googling.<br>So you just provide a single HDMI output, and hardware splits image on left and right.<br>As for your mentioned screen - I did not find any solutions for "splitting" image for such a glass-related tiny monitors.<br>You can look at tilt5 project - they use a couple of a tiny HD projectors for their VR glasses. But, to say the true, I was not able to find some more details on hardware they use.<br>p.s. If you decide to go this coupled-screen way, please take into account, that RPi can give you 1920x1080 maximum resolution (but not 4K) from the cameras.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon Apr 27, 2020 9:30 am</p><hr />
		<updated>2020-04-27T00:39:43+00:00</updated>
		<published>2020-04-27T00:39:43+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1899#p1899</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1899#p1899"/>
		<title type="html"><![CDATA[Connecting stereopi to two displays?]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1899#p1899"><![CDATA[
I know it's possible to connect the stereopi to a single screen (and indeed this is a strength), but I want to do a project where I connect a single stereopi (with the two cameras) to two separate screens. More specifically, I want to connect it to two of these <a href="https://www.amazon.com/Vufine-006011-Wearable-Display/dp/B01MZ89QXF/ref=sr_1_10?dchild=1&amp;keywords=ar+glasses&amp;qid=1587947836&amp;sr=8-10" class="postlink">https://www.amazon.com/Vufine-006011-We ... 36&amp;sr=8-10</a><br><br>You can see someone connect a single raspberry pi camera to one of them here: <a href="https://www.youtube.com/watch?v=px2hdZJLC3A&amp;t=1s" class="postlink">https://www.youtube.com/watch?v=px2hdZJLC3A&amp;t=1s</a><br><br>My question is if it's possible to connect the stereoscope to two of these things (essentially displays that you connect to via an HDMI connection)? And if so, would I experience some of the issues the stereopi is meant to address (latency, differing delays between trying to sync two cameras before the stereopi came around, etc...). <br><br>Would love some guidance!<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=383">MWaddell</a> — Mon Apr 27, 2020 12:39 am</p><hr />
