	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/912" />
	<updated>2020-04-19T13:10:35+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/912</id>
		<published>2020-04-19T13:10:35+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1876#p1876</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1876#p1876"/>
		<title type="html"><![CDATA[Re: OpenCv installing Troubleshooting]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1876#p1876"><![CDATA[
"undefined symbol: __atomic_fetch_add8" error is known issue on RPi. You need top install a specific version of OpenCV.<br>For Open cv 3.x workaround is to use <div class="codebox"><p>Code: </p><pre><code>sudo pip3 install opencv-python==3.4.6.27</code></pre></div>For OpenCV 4.x use this command:<div class="codebox"><p>Code: </p><pre><code>sudo pip3 install opencv-contrib-python==4.1.0.25</code></pre></div>We will update our guide on Github, thank you!<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Sun Apr 19, 2020 1:10 pm</p><hr />
		<author><name><![CDATA[dragon]]></name></author>
		<updated>2020-04-18T22:49:21+00:00</updated>
		<published>2020-04-18T22:49:21+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1873#p1873</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1873#p1873"/>
		<title type="html"><![CDATA[OpenCv installing Troubleshooting]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1873#p1873"><![CDATA[
I read your paper <a href="https://stereopi.com/blog/opencv-comparing-speed-c-and-python-code-raspberry-pi-stereo-vision" class="postlink">https://stereopi.com/blog/opencv-compar ... reo-vision</a> and <a href="https://github.com/realizator/stereopi-fisheye-robot/blob/master/buster-opencv-notice.md" class="postlink">https://github.com/realizator/stereopi- ... -notice.md</a>. I cannot install OpenCV without trouble. I get <a href="https://github.com/EdjeElectronics/TensorFlow-Object-Detection-on-the-Raspberry-Pi/issues/67" class="postlink">https://github.com/EdjeElectronics/Tens ... /issues/67</a> or other packages problems. I do it as written in your instruction.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=346">dragon</a> — Sat Apr 18, 2020 10:49 pm</p><hr />
