	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/907" />
	<updated>2022-04-04T10:55:20+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/907</id>
		<published>2022-04-04T10:55:20+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3094#p3094</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3094#p3094"/>
		<title type="html"><![CDATA[Re: IMX219-83 Stereo Camera Waveshare]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3094#p3094"><![CDATA[
Hey stoffel61,<br><br>It just works, no special updates here.<br>I also found that the plastic base for the optics used on IMX219-83 is physically compatible with a few other Waveshare M12 cameras. I.e., you can swap them using just 2 screws on the back side of the camera.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon Apr 04, 2022 10:55 am</p><hr />
		<author><name><![CDATA[stoffel61]]></name></author>
		<updated>2022-03-19T16:58:26+00:00</updated>
		<published>2022-03-19T16:58:26+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=3086#p3086</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=3086#p3086"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=3086#p3086"><![CDATA[
Hi,<br><br>is there any news about tne IMX219-83 as it is in the market now?<br><br>Best regards,<br>Chris<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=1028">stoffel61</a> — Sat Mar 19, 2022 4:58 pm</p><hr />
		<updated>2020-04-10T10:43:07+00:00</updated>
		<published>2020-04-10T10:43:07+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1849#p1849</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1849#p1849"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1849#p1849"><![CDATA[
Hi JtLadD,<br>Actually, when you have both horizontal and vertical offsets, it is similar to rotating horizontal offset at some angle. But your images should be rotated too. <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":-)" title="Smile"> I don't think that basic OpenCV calibration procedure will manage this out, but I'm curious to try this.<br>You see, "double axis offset" useful for detection of a disparity for horizontal lines (which are mostly invisible by horizontal offset), and also gives you some more distance between cameras (stereo base), as it is a diagonal size of a rectangular setup.<br>As for IMX219-83 (mentioned in our <a href="https://stereopi.com/blog/rpi-camera-v2-crypto-chip-features-compute-module-and-nvidia-jetson-nano" class="postlink">last update</a>) - we are waiting for delivery of this item to test it. It looks interesting, as it is cheaper than a couple of camera modules, but also has  additional features (like IMU) onboard. Also it has a relatively small FOV 83/73/50 degree (diagonal/horizontal/vertical). I will try to replace optics to wide angle, as used optics looks like a classic M12.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Fri Apr 10, 2020 10:43 am</p><hr />
		<author><name><![CDATA[JtLadD]]></name></author>
		<updated>2020-04-10T10:29:02+00:00</updated>
		<published>2020-04-10T10:29:02+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1848#p1848</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1848#p1848"/>
		<title type="html"><![CDATA[IMX219-83 Stereo Camera Waveshare]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1848#p1848"><![CDATA[
This is very interesting to me as I already  <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_cool.gif" width="15" height="17" alt="8-)" title="Cool"> have a Leica BLK3D which is essentially the same with the addition of a laser distance metre which measures the distance to the approximate (?) centre of the image. This gives scale and orientaion of the pairs.<br>One other thing about the BLK3D that I do not yet see from Stereopi users is that the cameras are offset both horizontally and vertically which I think helps with the stereo computation.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=372">JtLadD</a> — Fri Apr 10, 2020 10:29 am</p><hr />
