	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/889" />
	<updated>2020-03-19T11:35:49+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/889</id>
		<author><name><![CDATA[megil]]></name></author>
		<published>2020-03-19T11:35:49+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1773#p1773</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1773#p1773"/>
		<title type="html"><![CDATA[Re: Depth Map Coloring Problem]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1773#p1773"><![CDATA[
I don't have this problem when using python code. I am encountering using c ++ code. My efforts to solve the issue continue. If I can't get a solution, I will send you the documents. Thank you for your answers. Sorry, my email address is no longer accessible. I need to change it.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=314">megil</a> — Thu Mar 19, 2020 11:35 am</p><hr />
		<updated>2020-03-17T19:31:41+00:00</updated>
		<published>2020-03-17T19:31:41+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1766#p1766</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1766#p1766"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1766#p1766"><![CDATA[
Hi Megil!<br>Wow, it's great you are here. Your email is not working, and I was try to contact you to help us with <a href="https://forum.stereopi.com/viewtopic.php?f=9&amp;t=886" class="postlink">this issue</a>. Can you please look at it? This issue is similar to the one you solved.<br><br>As for your question - looks like you depth maps settings are not so good, and mindisp/numofdisp settings are not ideal. If you can share with me your chessboard photos set, current depth map settings and several images for building a depth map - I will try to figure out, what's wrong. You can upload it to the cloud (like Google drive) and send me a link here on forum, or by email (my nickname @gmail . com) <br>By the way, are you using C++ or Python code?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Tue Mar 17, 2020 7:31 pm</p><hr />
		<updated>2020-03-17T15:11:02+00:00</updated>
		<published>2020-03-17T15:11:02+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1765#p1765</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1765#p1765"/>
		<title type="html"><![CDATA[Depth Map Coloring Problem]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1765#p1765"><![CDATA[
Hello everyone,<br><br>I follow this page;<br><br><a href="https://stereopi.com/blog/opencv-comparing-speed-c-and-python-code-raspberry-pi-stereo-vision" class="postlink">https://stereopi.com/blog/opencv-compar ... reo-vision</a><br><br>My depth map ;<br><a href="https://imgbb.com/" class="postlink"><img src="https://i.ibb.co/x1Z9CGh/Screenshot.png" class="postimage" alt="Image"></a><br><br><br>I have been dealing with this issue for a long time. I have information about stereo vision. Although I have set all the parameters, it sees the first 2-3 meters in red.<br><br><br>So the first 2-3 meters are always red. 1. meter red [128,0,0], 2.meter red [128,0,0] 3.meter [252,0,0].<br><br>It gets better after the 3. meter. But before that, it is always red. It doesn't change if I change the parameters.<br><br>How can i fix it?<br><br>Thanks in advance.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=314">megil</a> — Tue Mar 17, 2020 3:11 pm</p><hr />
