	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/884" />
	<updated>2021-07-27T12:23:30+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/884</id>
		<published>2021-07-27T12:23:30+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2765#p2765</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2765#p2765"/>
		<title type="html"><![CDATA[Re: camera 1 cannot show image]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2765#p2765"><![CDATA[
Wow.. the cameras should work exactly the same way.<br>- Please show us the code you are using to capture the images<br>- Are you using the HQ hardware sync trick?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Tue Jul 27, 2021 12:23 pm</p><hr />
		<author><name><![CDATA[GesirenNickZhang]]></name></author>
		<updated>2021-07-12T19:26:31+00:00</updated>
		<published>2021-07-12T19:26:31+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2759#p2759</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2759#p2759"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2759#p2759"><![CDATA[
<blockquote class="uncited"><div>GesirenNickZhang, congrats on finding this iris issue! I got the same with my first HQ camera experiments <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":-)" title="Smile"><br>As for your USB drive issue - are you able to copy any other files to your drive? I faced a similar issue when the USB drive was removed from Windows incorrectly. In this case, it can be seen as "read-only" by Raspberry OS (and by MacOS too, BTW).<br>To fix this you can insert it into your Win machine and eject it in the right manner (using the "eject" option).<br><br>If this does not help, could you please provide us more details (like the size of your flash drive and the file system type)?</div></blockquote>Hi,<br>I hope you are doing well, and thanks for blessing us with your awesome work. I am reaching out again regarding an issue I have while taking pictures with my HQ cameras. After I turn the camera livestream on and start taking stereo pair images (using basically the same code as your 1_test.py in the tutorials with some edits allowing me to take not just one but multiple pairs before breaking), one camera's live feed would freeze after I take a few images. My guess is that there is some bottlenecking happening somewhere - what could the problem be? I am happy to provide my code or anything else you need. Thanks again.<br>-N<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=361">GesirenNickZhang</a> — Mon Jul 12, 2021 7:26 pm</p><hr />
		<updated>2020-10-19T23:18:27+00:00</updated>
		<published>2020-10-19T23:18:27+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2299#p2299</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2299#p2299"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2299#p2299"><![CDATA[
<blockquote class="uncited"><div>GesirenNickZhang, congrats on finding this iris issue! I got the same with my first HQ camera experiments <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":-)" title="Smile"><br>As for your USB drive issue - are you able to copy any other files to your drive? I faced a similar issue when the USB drive was removed from Windows incorrectly. In this case, it can be seen as "read-only" by Raspberry OS (and by MacOS too, BTW).<br>To fix this you can insert it into your Win machine and eject it in the right manner (using the "eject" option).<br><br>If this does not help, could you please provide us more details (like the size of your flash drive and the file system type)?</div></blockquote>Hi, it made the ready-only go away but gave me the permission error instead. Anyway, I connected the board to the net via ethernet and uploaded my files to one drive so that I open access them elsewhere.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=361">GesirenNickZhang</a> — Mon Oct 19, 2020 11:18 pm</p><hr />
		<updated>2020-10-18T12:34:35+00:00</updated>
		<published>2020-10-18T12:34:35+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2294#p2294</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2294#p2294"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2294#p2294"><![CDATA[
GesirenNickZhang, congrats on finding this iris issue! I got the same with my first HQ camera experiments <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":-)" title="Smile"><br>As for your USB drive issue - are you able to copy any other files to your drive? I faced a similar issue when the USB drive was removed from Windows incorrectly. In this case, it can be seen as "read-only" by Raspberry OS (and by MacOS too, BTW).<br>To fix this you can insert it into your Win machine and eject it in the right manner (using the "eject" option).<br><br>If this does not help, could you please provide us more details (like the size of your flash drive and the file system type)?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Sun Oct 18, 2020 12:34 pm</p><hr />
		<updated>2020-10-16T19:08:24+00:00</updated>
		<published>2020-10-16T19:08:24+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2289#p2289</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2289#p2289"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2289#p2289"><![CDATA[
<blockquote class="uncited"><div>GesirenNickZhang, did you try to swap cameras, and run the same command again?</div></blockquote>Hi,<br><br>I made a dumb mistake by closing the aperture all the way down  <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_lol.gif" width="15" height="17" alt=":lol:" title="Laughing"> It is all good now <br><br>Now I have several hundred MB worth of pictures needed to be exported, and I tried to save them onto my external USB drive but failed - when I drag the pictures into my drive, they refuse to get saved. Is there a way to save them at all?<br><br>Thanks<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=361">GesirenNickZhang</a> — Fri Oct 16, 2020 7:08 pm</p><hr />
		<updated>2020-10-01T20:06:14+00:00</updated>
		<published>2020-10-01T20:06:14+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2278#p2278</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2278#p2278"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2278#p2278"><![CDATA[
GesirenNickZhang, did you try to swap cameras, and run the same command again?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Thu Oct 01, 2020 8:06 pm</p><hr />
		<updated>2020-10-01T18:00:28+00:00</updated>
		<published>2020-10-01T18:00:28+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=2277#p2277</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=2277#p2277"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=2277#p2277"><![CDATA[
<blockquote class="uncited"><div>GesirenNickZhang, I don't like magic while making... But I hope it will work for you. <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":-)" title="Smile"></div></blockquote>I got a pair of RP HQ cams, while they are both supported and detected, when I run the raspistill -cs command, I got live video from one camera but just black screen from the other (yes I did remove the lens protector). Any idea why this is happening?<br><br>thanks<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=361">GesirenNickZhang</a> — Thu Oct 01, 2020 6:00 pm</p><hr />
		<updated>2020-03-14T13:02:22+00:00</updated>
		<published>2020-03-14T13:02:22+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1753#p1753</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1753#p1753"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1753#p1753"><![CDATA[
GesirenNickZhang, I don't like magic while making... But I hope it will work for you. <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":-)" title="Smile"><p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Sat Mar 14, 2020 1:02 pm</p><hr />
		<updated>2020-03-13T17:20:10+00:00</updated>
		<published>2020-03-13T17:20:10+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1752#p1752</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1752#p1752"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1752#p1752"><![CDATA[
Hi,<br><br>I came back this morning and my thing magically works. Now let's hope it will keep working after I get longer ribbons.<br><br>N<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=361">GesirenNickZhang</a> — Fri Mar 13, 2020 5:20 pm</p><hr />
		<updated>2020-03-12T20:12:44+00:00</updated>
		<published>2020-03-12T20:12:44+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1750#p1750</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1750#p1750"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1750#p1750"><![CDATA[
<blockquote class="uncited"><div>Hi GesirenNickZhang,<br>Can you please check, if system behavior changes if you will swap cameras? Will your disenabled camera work in another CSI connector of the StereoPi?</div></blockquote>Hey man,<br><br>I went back to my lab today and did more testing. The good camera + ribbon from yesterday was plugged into the CSI port near the HDMI port today and the image came up just fine. I then tried out several camera module + ribbon combinations on the other CSI port and was getting "supported=2 detected=1". The error message for raspistill is OV5647 and could not select camera: error 3.<br><br>To me it seems I only have one good camera module and the rest camera modules are both bad (including one from the starter kit). Any thoughts?<br><br>thanks,<br>-N<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=361">GesirenNickZhang</a> — Thu Mar 12, 2020 8:12 pm</p><hr />
		<updated>2020-03-12T14:17:00+00:00</updated>
		<published>2020-03-12T14:17:00+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1748#p1748</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1748#p1748"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1748#p1748"><![CDATA[
Hi GesirenNickZhang,<br>Can you please check, if system behavior changes if you will swap cameras? Will your disenabled camera work in another CSI connector of the StereoPi?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Thu Mar 12, 2020 2:17 pm</p><hr />
		<updated>2020-03-11T21:24:53+00:00</updated>
		<published>2020-03-11T21:24:53+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1746#p1746</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1746#p1746"/>
		<title type="html"><![CDATA[camera 1 cannot show image]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1746#p1746"><![CDATA[
Hello,<br><br>I purchased a StereoPi starter kit. When using the two cameras in the box and running vcgencmd get_camera, I got supported=2 detected=1, so I went ahead to replace the undetected camera with an official Pi cam module.<br><br> When I run vcgencmd get_camera gain, it then showed "supported=2 detected=2".<br><br>When running raspistill -cs 0, a live video from a camera shows up.<br><br>When running raspistill -cs 1, it says:<br>mmal: mmal_vc_component_enable: failed to enable component: EN0SPC<br>mmal: camera component couldn't be enabled<br>mmal: main: Failed to create camera component<br>mmal: Failed to run camera app. Please check for firmware updates<br><br>My OS on the SD card is written from the Raspbian Buster OpenCV Image (Python Code) download on the wiki.<br><br>May I receive some help? Thank you for your time.<br>-N<br><br>Edit: The disenabled camera is connected to the port right next to the HDMI port.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=361">GesirenNickZhang</a> — Wed Mar 11, 2020 9:24 pm</p><hr />
