	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/883" />
	<updated>2020-03-10T13:23:51+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/883</id>
		<published>2020-03-10T13:23:51+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1740#p1740</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1740#p1740"/>
		<title type="html"><![CDATA[Re: Recommended Global-Shutter Cameras]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1740#p1740"><![CDATA[
You can consider SE397GS-01-CB cameras from Soho Enterprise.<br>Here is a description: <a href="https://soho-enterprise.com/wp/wp-content/uploads/2019/05/SE397-CB-Product-Brief-1_1_0.pdf" class="postlink">https://soho-enterprise.com/wp/wp-conte ... -1_1_0.pdf</a><br>These cameras are using unused LED line in a ribbon cable for sync signal. So you can do a synchronization without soldering.<br>I have a couple of such a cameras, and plan to test them in the nearest time.<br>You should understand, that these cameras are not supported by raspivid/raspistill, and you need to use raspiraw or another approach for them.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Tue Mar 10, 2020 1:23 pm</p><hr />
		<author><name><![CDATA[majs]]></name></author>
		<updated>2020-03-10T12:54:38+00:00</updated>
		<published>2020-03-10T12:54:38+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1738#p1738</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1738#p1738"/>
		<title type="html"><![CDATA[Recommended Global-Shutter Cameras]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1738#p1738"><![CDATA[
Hello,<br><br>I was wondering, if you could recommend monochrome global shutter cameras that are compatible with the StereoPi.<br>If they also incorporate a trigger signal, that would be perfect.<br><br>Best Regards<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=357">majs</a> — Tue Mar 10, 2020 12:54 pm</p><hr />
