	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/881" />
	<updated>2020-03-10T13:29:59+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/881</id>
		<published>2020-03-10T13:29:59+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1741#p1741</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1741#p1741"/>
		<title type="html"><![CDATA[Re: Arducam motorized focus camera modules]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1741#p1741"><![CDATA[
Hi Davidheiserca,<br>I'm not familiar with right these modules. If they use a couple more cables to connect I2C to focusing motor, or they use I2C line from the camera ribbon cable? On the StereoPi you need to do a correction of the device tree (dt-blob) to do a correct assignment of the I2C you use.<br><br>For the raspivid/raspistill I2C is occupied by the VPU, so you have no direct access to it. But for the V4L you can use it.<br>You can also search for "arducam" on our forum, as several users already asked a similar I2C questions for the Arducam cameras.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Tue Mar 10, 2020 1:29 pm</p><hr />
		<author><name><![CDATA[davidheiserca]]></name></author>
		<updated>2020-03-09T01:13:49+00:00</updated>
		<published>2020-03-09T01:13:49+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1735#p1735</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1735#p1735"/>
		<title type="html"><![CDATA[Arducam motorized focus camera modules]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1735#p1735"><![CDATA[
I want to integrate two Arducam motorized focus camera modules into the 3D StereoPi camera I built.<br><br>The focus is controlled using i2cset. It works fine on a Pi3 using a command like "i2cset -y 0 0x0c 12 128".<br><br>Is it possible to do this on a StereoPi?<br><br>The "i2cdetect -y 1" command indicates that there are no devices detected on i2c-1.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=254">davidheiserca</a> — Mon Mar 09, 2020 1:13 am</p><hr />
