	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/862" />
	<updated>2020-02-12T15:18:06+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/862</id>
		<published>2020-02-12T15:18:06+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1613#p1613</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1613#p1613"/>
		<title type="html"><![CDATA[Re: Combining 2 x 2 cameras for a 360° car surround solution]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1613#p1613"><![CDATA[
Hi Jens,<br>Your idea looks cool! <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":-)" title="Smile"> <br>I have several notices on this, which may help you to avoid some problems.<br>1. Slim camera cables<ul><li>Actually, there are no such a cables on market. They exist for another cameras (as a rule for the FPV drones), like <a href="https://shop.runcam.com/customized-lens-extension-cable-for-runcam-2/" class="postlink">this for RunCam</a> or <a href="https://www.mobius-actioncam.com/store/products/mobius-8-inch-lens-extension-cable" class="postlink">this one for Mobius</a>, but incompatible with RPi cameras.</li></ul><ul><li>Also, if you will use a classic camera ribbon cables, but longer (50 cm, 1 m etc), you can face a problem with capturing electromagnetic noise on that cable. Camera will be detected, but will not work. You need to do a shield to defend it.</li></ul><ul><li>You can consider using HDMI cable to extend camera cable length. There are several adapters on market, like <a href="https://www.tindie.com/products/freto/pi-camera-hdmi-cable-extension/" class="postlink">this one</a>. With this kit you can do a VERY long cables (like 5 meters).</li></ul>2. Combining 4 cameras<br>It is not a problem to use a couple of StereoPis and get 4 videos. But stitching is a challenge. For real-time stitching you'll need to find good algorithm and create a code for the real-time stitching. I don't know any ready-to-use solutions for this (but may be my google skills are not so good <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":)" title="Smile"> ).<br><br>I'd prefer to do a simple MVP to test this concept before spending your money on StereoPi, cameras and cable extenders. For example, you can take several PiZeros with the cameras, and stream a video from them to a "main" device like RPi4 (by Ethernrt or WiFi). If this will work - you can try to implement more advanced solution, using StereoPi. IMHO stitching of 4 videos is the key potential problem here (RPi performance). May be NVidia Jetson as a big brother for stitching?.. <br><br>Offtop: before creating the StereoPi, we've tested a concept of stereoscopic video with by creating this simple add-on to the RPi camera, 3Dberry: <a href="http://3dberry.org/sites/default/files/3dberry_light.jpg" class="postlink">http://3dberry.org/sites/default/files/ ... _light.jpg</a> And only after that we decided to spend our time and money for the StereoPi development, as this simple device shows us, that this approach is working.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Wed Feb 12, 2020 3:18 pm</p><hr />
		<author><name><![CDATA[Brooklyn701]]></name></author>
		<updated>2020-02-12T11:30:47+00:00</updated>
		<published>2020-02-12T11:30:47+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1612#p1612</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1612#p1612"/>
		<title type="html"><![CDATA[Combining 2 x 2 cameras for a 360° car surround solution]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1612#p1612"><![CDATA[
Hi guys,<br><br>just wanted to get you views on this before I started with my project. I wanted to enhance my old car from the 2000s and add 360° cameras to it. So I was looking for a Raspberry Pi Kit that would help me do that. StereoPi seems great, but I'd like to know if it is possible to combine 4 cameras and stich these together?<br><br>Also are there any alternative camera cables (slimmer)? Because the flat cables will be tough to insert throughout the car.<br><br>I'd be greatful for comments and suggestions. <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":)" title="Smile"><br><br>Regards Jens<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=341">Brooklyn701</a> — Wed Feb 12, 2020 11:30 am</p><hr />
