	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/851" />
	<updated>2020-01-17T14:44:04+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/851</id>
		<published>2020-01-17T14:44:04+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1578#p1578</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1578#p1578"/>
		<title type="html"><![CDATA[Re: command line]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1578#p1578"><![CDATA[
Stereomaton thank you! <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":-)" title="Smile"><br>Bchamp, do not forget to unlock a filesystem before changes! Also we have MC installed in SLP, so you can use it if you like.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Fri Jan 17, 2020 2:44 pm</p><hr />
		<updated>2020-01-17T08:41:20+00:00</updated>
		<published>2020-01-17T08:41:20+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1574#p1574</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1574#p1574"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1574#p1574"><![CDATA[
If you use SLP variant of the operating system (which is the default delivered with the kit), remote console access is enabled by default through SSH protocole. See <a href="https://wiki.stereopi.com/index.php?title=SLP_%28StereoPi_Livestream_Playground%29_Raspbian_Image#Advanced_users.E2.80.99_section" class="postlink">https://wiki.stereopi.com/index.php?tit ... 99_section</a> for credentials.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=101">stereomaton</a> — Fri Jan 17, 2020 8:41 am</p><hr />
		<author><name><![CDATA[bchamp]]></name></author>
		<updated>2020-01-16T23:06:00+00:00</updated>
		<published>2020-01-16T23:06:00+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1570#p1570</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1570#p1570"/>
		<title type="html"><![CDATA[command line]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1570#p1570"><![CDATA[
How can I set up the stereopi to access the command line? I would like to run scripts to take pictures at specific time intervals<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=330">bchamp</a> — Thu Jan 16, 2020 11:06 pm</p><hr />
