	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/825" />
	<updated>2019-12-24T13:46:01+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/825</id>
		<author><name><![CDATA[megil]]></name></author>
		<published>2019-12-24T13:46:01+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1465#p1465</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1465#p1465"/>
		<title type="html"><![CDATA[Re: Stereo Pi and Ubuntu Mate.]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1465#p1465"><![CDATA[
Thanks for answers. <br><br>I solved this problem.<br><br>The operating system on my memory card has two parts. <br>The first is "system-boot", the second is "writable". <br>I located "dt-blob.bin" file "/writable/boot". <br>But you have to locate it into the "system-boot" partition.<br><br>I'd appreciate it if you'd add it to the wiki.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=314">megil</a> — Tue Dec 24, 2019 1:46 pm</p><hr />
		<updated>2019-12-23T12:32:10+00:00</updated>
		<published>2019-12-23T12:32:10+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1458#p1458</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1458#p1458"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1458#p1458"><![CDATA[
<blockquote class="uncited"><div>Hi Realizator,<br><br>I already put dt-blob.bin in the boot directory. But it didn't help. <br><br>There is another file named dt-blob.dst. Do you know anything about this ?</div></blockquote>Megil, dt-blob.dts is a source file for the dt-blob.bin We compiled BIN from DTS.<br>You can find both here in our Wiki: <a href="https://wiki.stereopi.com/index.php?title=DIY_Ninjas_Section#Device_tree_.28DTS_and_dt-blob.bin.29" class="postlink">https://wiki.stereopi.com/index.php?tit ... lob.bin.29</a><p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon Dec 23, 2019 12:32 pm</p><hr />
		<updated>2019-12-23T12:18:00+00:00</updated>
		<published>2019-12-23T12:18:00+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1457#p1457</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1457#p1457"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1457#p1457"><![CDATA[
Hi Realizator,<br><br>I already put dt-blob.bin in the boot directory. But it didn't help. <br><br>There is another file named dt-blob.dst. Do you know anything about this ?<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=314">megil</a> — Mon Dec 23, 2019 12:18 pm</p><hr />
		<updated>2019-12-23T10:40:53+00:00</updated>
		<published>2019-12-23T10:40:53+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1455#p1455</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1455#p1455"/>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1455#p1455"><![CDATA[
<blockquote class="uncited"><div>Hello everyone,<br><br>I have a memory card that installed ubuntu mate and ros. <br><br>I can use them with any raspberry pi. But when I connect the stereo pi, it doesn't see the cameras. <br><br>Is there a file like "dt-blob.bin" for ubuntu mate users?<br><br>Thanks in advance.</div></blockquote>Hi Megli,<br>As I understand, Ubuntu Mate has some Rsapbian-specific support under the hood, including device tree (look at <a href="https://www.raspberrypi.org/forums/viewtopic.php?t=231983" class="postlink">this thread</a>).<br>Please try to put our <a href="http://wiki.stereopi.com/files/dt-blob.bin.zip" class="postlink">dt-blob.bin</a> in your boot partition and test it again. Please unzip it before use.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Mon Dec 23, 2019 10:40 am</p><hr />
		<updated>2019-12-23T08:46:46+00:00</updated>
		<published>2019-12-23T08:46:46+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=1454#p1454</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=1454#p1454"/>
		<title type="html"><![CDATA[Stereo Pi and Ubuntu Mate.]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=1454#p1454"><![CDATA[
Hello everyone,<br><br>I have a memory card that installed ubuntu mate and ros. <br><br>I can use them with any raspberry pi. But when I connect the stereo pi, it doesn't see the cameras. <br><br>Is there a file like "dt-blob.bin" for ubuntu mate users?<br><br>Thanks in advance.<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=314">megil</a> — Mon Dec 23, 2019 8:46 am</p><hr />
