	<link rel="self" type="application/atom+xml" href="https://forum.stereopi.com/app.php/feed/topic/36" />
	<updated>2019-05-14T09:51:02+00:00</updated>
	<id>https://forum.stereopi.com/app.php/feed/topic/36</id>
		<published>2019-05-14T09:51:02+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=122#p122</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=122#p122"/>
		<title type="html"><![CDATA[Re: Google Coral Installation with Compute Modules]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=122#p122"><![CDATA[
Dave, thank you for your guide!<br>I've added it to our Wiki <a href="https://wiki.stereopi.com/index.php?title=Advanced_User_Section#Google_Coral_Installation_with_Compute_Modules" class="postlink">here</a>.<br>It will be great if you will share your Google Coral experience with us! <img class="smilies" src="https://forum.stereopi.com/images/smilies/icon_e_smile.gif" width="15" height="17" alt=":-)" title="Smile"><p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=2">Realizator</a> — Tue May 14, 2019 9:51 am</p><hr />
		<author><name><![CDATA[xanatos]]></name></author>
		<updated>2019-05-13T22:40:53+00:00</updated>
		<published>2019-05-13T22:40:53+00:00</published>
		<id>https://forum.stereopi.com/viewtopic.php?p=117#p117</id>
		<link href="https://forum.stereopi.com/viewtopic.php?p=117#p117"/>
		<title type="html"><![CDATA[Google Coral Installation with Compute Modules]]></title>
		<content type="html" xml:base="https://forum.stereopi.com/viewtopic.php?p=117#p117"><![CDATA[
If you're planning to install Google's Coral Accelerator with EdgeTPU support, you will need to edit the install.sh file that is ready after you download and untar the tarball.  The install.sh script checks <br><div class="codebox"><p>Code: </p><pre><code>    cat /sys/firmware/devicetree/base/model</code></pre></div>and compares that string to the stored strings.  The Compute Module is not listed among them.  I have included here the entire section with the Compute Module's Model Line included:<br><div class="codebox"><p>Code: </p><pre><code>    if [[ "${MODEL}" == "Raspberry Pi 3 Model B Rev"* ]]; then        info "Recognized as Raspberry Pi 3 B."        LIBEDGETPU_SUFFIX=arm32        HOST_GNU_TYPE=arm-linux-gnueabihf    elif [[ "${MODEL}" == "Raspberry Pi 3 Model B Plus Rev"* ]]; then        info "Recognized as Raspberry Pi 3 B+."        LIBEDGETPU_SUFFIX=arm32        HOST_GNU_TYPE=arm-linux-gnueabihf    elif [[ "${MODEL}" == "Raspberry Pi Compute Module 3 Plus Rev"* ]]; then        info "Recognized as Raspberry Pi CM3+."        LIBEDGETPU_SUFFIX=arm32        HOST_GNU_TYPE=arm-linux-gnueabihf    fi</code></pre></div>Save that and run the script.  Installation of EdgeTPU will be successfully completed.<br><br>Dave Xanatos<p>Statistics: Posted by <a href="https://forum.stereopi.com/memberlist.php?mode=viewprofile&amp;u=52">xanatos</a> — Mon May 13, 2019 10:40 pm</p><hr />
